I have so far used only 3-2 indoors.RJJ wrote: In the process of building myself one, what v2 arm mounts should I start with, running on astroturf mainly over here or carpet indoors.
-N-[/quote]
Thankyou
Roasty71 wrote: 1x V2 Arm set from shapeways - YES
1x #1777 shocks ends - YES, if you dont have some already laying around
1x #9645 screws for retaining the hinge pins - YES, same as above
1x #6220 front inline axles from a B4, could i use a B4.2 set up so i can use hex wheels ? - Yes/No - I would try to find original front axles from 10T/GT/T2/Team/Worlds car, the B4 axles will need to be drilled.
1x #9672 Rear CVA bones , do they fit straight on to the RERE axles or do i fit B4.2 and again use hex rear wheels. - YES, fits and you can use pin or hex B4 series wheels.
1x #9696 rear wheels, are these pin or hex wheels? - these are hex, use your choice of wheel
1x #73392 RPM rod ends - not sure (someone else?)
1x #7305 Nose plate (10T/GT) shapeways - YES (not shapeways, its an alloy part)
1x #7207 Front bulkhead (10T/GT) shapeways - YES (not sure if this is on shapeways)
1x #7315 Nose brace tubes (10T/GT) shapeways - YES (not shapeways, its an alloy part)
Also do i need the front and rear towers ? - Front tower, YES, rear tower, NO, but its nice to have the newer towers with B5 wing mount holes already in it (you will need B5M wing mounts as well).
JK Racing wrote:Best I can answer...
Users browsing this forum: Ahrefs [Bot] and 52 guests
