What POSSIBLE reason........
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
Re: What POSSIBLE reason........
Most important thing is it will prevent the motormount plate from getting bent too quick.
- Has thanked: 28 times
- Been thanked: 957 times
I don't have a whole lot to update on this build. I've done some stuff to it, but it's kinda been on the back burner. But i do have a question that someone may be able to help me out with.
I'm a little hung up on front wheels for this thing due to the bearing size. So I stumbled across these Tamiya TRF-201 front wheels:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXABZX&P=SM
Does anyone know if these take a standard 5x11 bearing? I'm assuming they do. I figured I could pick up a pair of these CRP front axles and I should be in good shape.
http://www.ebay.com/itm/FRONT-AXLE-Tamiya-Wheel-to-Kyosho-Ultima-use-5x11x4mm-Bearing-RC-Team-CRP-1712-/351363936535?pt=LH_DefaultDomain_0&hash=item51ceec3117
- Has thanked: 818 times
- Been thanked: 2399 times
Actually, you can slide that 8mm outer bearing right into an associated wheel made for a 5/16 flanged too if it helps
Factory Works website
- Incredible_Serious
- Has thanked: 1386 times
- Been thanked: 850 times
scr8p wrote:I don't have a whole lot to update on this build. I've done some stuff to it, but it's kinda been on the back burner. But i do have a question that someone may be able to help me out with.
Looking at the TRF201 manual here http://www.tamiya.com/english/rc/manuals.htm shows the 201 having 5x10 front wheel bearings... so as long as it's a 5mm axle, you should be right, just get 1050s instead of 1150s - raid your Kyosho stocks.
I actually did that messing around, but I'm wanting to use 2.2 wheels/modern tires and the AE wheels are for 3/8 bearings.gomachv wrote:Actually, you can slide that 8mm outer bearing right into an associated wheel made for a 5/16 flanged too if it helps
You guys and your looking at manuals.Incredible_Serious wrote:Looking at the TRF201 manual here http://www.tamiya.com/english/rc/manuals.htm shows the 201 having 5x10 front wheel bearings... so as long as it's a 5mm axle, you should be right, just get 1050s instead of 1150s - raid your Kyosho stocks.
Thanks for looking it up.
I look at manuals, follow recipes, and read instructions..... yup, I'm THAT guy.scr8p wrote: You guys and your looking at manuals.
- Mr. ED
Lately i like using u1457w from shumacher with 840 beaings and stock axles. They are narrower and 2.1 but perfect for staggered ribs.
Durango also had usable wheels, but the bearings are spread too far apart for the crp axles. Let us know how the trf ones work out: Always good to have a more current option.
- Seabass
- Business Member
- Been thanked: 12 times
Jason, what you need are custom aluminum axles what will fit SAE bearings.
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
Tamiya has an option set of axles for the TRF201 that fit SAE bearings.
http://www.tamiyausa.com/items/radio-control-parts-70/hop-up-parts-72000/rc-trf201-front-axle-54220
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
I´m shocked - We´re talking about one of the finest racing instruments ever made
As if it wasn´t bad enough with the tranny, new suggestions points towards using Tamiya
This is outrageous!
This is outrageous!
Gone fishing
- Mr. ED
That's a tamiya Baja Champ from '98.jwscab wrote:Hey Ed,
what body is that you had shown on page 7 at the bottom with the green 'scales'?
Here's another one with different livery, mounted on my latest ultima build: http://www.rc10talk.com/viewtopic.php?f=30&t=37607&start=15
By the way: I have bought another of the sliding steering racks from Custom works not long ago. The quality has really gone up quite a bit. They look identical, but the old one I had to put in a lot of work to get it working smoothly. The new one works perfect straight out of the bag.
- Mr. ED
I found out those trf wheels are available in yellow too and ordered me 2 sets. Let's hope they work
- Mr. ED
Me... again
Yokomo b2-821 takes 5x10 bearings and is narrower than the durango 210 wheels where the bearings are located.
(NOT b2-821HW or b2-821HY!)
Well, I got back on this today. I spent a lot of yesterday trying to straighten up my R/C area.......get some stuff organized, etc. Now that my main workbench is about the cleanest it's been in years I thought I'd mess around with this a little bit, so on to the front end.
So I wanted to use axles that would make wheel choice easier. So I decided i wanted to try a stock rc10 aluminum inline axle. The portion that goes into the Ultima knuckle is too small of a diameter. Also, the kingpin hole is also too small. So i cut some strips from a soda can to wrap around the axle for some added girth (the women like that ) to give it a tighter fit. I also had to drill it out to fit the larger kingpin. To do this the right way, I need to have new axle made. One day that will happen, but for now this works.
Front track width is dead on to my Jrx-Pro with old school wheels so I'm happy. But if I wanted to use b4 wheel, I'll need longer ones.
Users browsing this forum: No registered users and 20 guests
