*Parts needed to run modern 2.2 rims/tires on your rc10*
General info, Q&A.
mark in wi
Re: *Parts needed to run modern 2.2 rims/tires on your rc10*
Post by mark in wi »
RC104ever wrote:Can you post a pic of how the fuel tubing was used?
Not sure how he did it. You cut a small piece and fit into the "cup" of the axle and outdrive. This stops the dog bone from going to the bottom of one side and falling out of the other. I think I used a piece of a foam earplug to get the same effect.
Hope this helps/makes sense.
Mark
JK Racing
Has thanked: 103 times
Been thanked: 200 times
Post by JK Racing »
wrong forum :oops: :oops:
CUDDZILLA
Post by CUDDZILLA »
Does anyone know if you can adapt touring car wheels(hex drive) to fit the rc10? Anybody? Bueller?
RC104ever
Post by RC104ever »
I don't know about touring car wheels, but here is how to do HPI hex drive wheels:
http://www.rc10talk.com/viewtopic.php?f=35&t=20904&hilit=+hpi+star
- Chris
Lots of cars...so many cars
rc10johnny
Post by rc10johnny »
SC10 Hex...... :shock: :mrgreen: Image
rc10johnny
rc10johnny
mark in wi
So what parts did you use to get the sc10 hex to work? Looks nice. How well does it work?
rc10johnny
mark in wi wrote:So what parts did you use to get the sc10 hex to work? Looks nice. How well does it work?
all associated except rhe 1/8 drill bit....caster block#7922..steering block# 9880....front axel#9881...3/16X3/8 bearings...$16.00...Proline makes a kit for $29.95...JohnnySr
toyranosaur
Business Member
Post by toyranosaur »
Maybe some Technacraft-style wheels that are slightly bigger bead depth? Then just bolt 'em on? Thoughts? Chris REC
mark in wi
Last night I was wondering if my CVDs from my tc3 would work since I have broken dog bone. I took everything off my rc10 and then the tc3. The bearings drooped right in! The "drive shaft" part was too short but the axel fit nicely. I took the Hexs and they seemed like they will work perfectly. Needless to say I could not try it out but it might help someone.
Mark
Phin
Has thanked: 60 times
Been thanked: 181 times
Post by Phin »
hairymuffin wrote:best thisng is using the hex instead of the pin,no stripped out wheels.. I added a green spacer on the hub,can be tuned to run the hubs forward or aft...Another good thing which was most important to me is that the cvd fits in the outdrive perfectly in the middle..Going to the track today to try it out guys
davidka wrote:Muffin, what's the track width of that compared to stock? Nice find.
Didn't see an answer to this questions...do the Kyosho hubs and CVDs change the track width at the rear?
18ri
Post by 18ri »
I put the B4 rear stub axle in an old RC10 by changing out the bearings. Then I installed the B4 rear wheels. Only problem is the B4 wheels have a greater offset than the RC10 wheels so the rear is now narrower than the RC10. Anyone else have this problem, and how did you get around it?
Thanks
fredswain
Post by fredswain »
Go back to the first page of this thread and start reading. There are various methods listed.
KHShapiro
Post by KHShapiro »
In the fronts i am using Blitz front hub assembly for use of hex on the fronts. On the rears I'm using Blitz (generation 1) rear axels and bearing in the stock RC10 hubs. I pressed in the bearings flush on the inside and outside . I used the hip blitz stuff because I had it on hand and it fit.
Post Reply
  • Modern rims/tires for vintage RC10 or how I gave up on old tires
    by Nero45 » » in Temple's RC10 Tech Forum
    Last post by XLR8
  • New/modern tires that will fit narrow front 10T rims?
    by AndrewSi » » in RC10 Truck Forum
  • Need help on parts needed for truck tires!
    by Jman115 » » in Temple's RC10 Tech Forum
    Last post by aconsola
  • RC10 Buggy Can I run modern B4 wheels?
    by ffpm46 » » in RC10 Buggy Forum
    Last post by fastang
  • Need new rims and tires for original RC10
    by veghead211 » » in RC10 Buggy Forum
    Last post by veghead211
  • rc10 modern parts listing
    by JosephS » » in R/C Off-Topic / Chit-Chat
    Last post by JosephS
  • rc10 ds modern wheel conversion parts
    by Luckyracing » » in Associated On-Road Forum
  • Lohas rims and what's needed
    by bow2986 » » in RC10 Buggy Forum
    Last post by bow2986
Users browsing this forum: No registered users and 13 guests
