MIKE DUNN PRO RADIANT Replica from the WC 89 in Australia.
- Lonestar
- Has thanked: 626 times
- Been thanked: 167 times
Re: MIKE DUNN PRO RADIANT Replica from the WC 89 in Australi
can I dumbly ask what the point of that front setup was? I've never seen anything like this Looks like it must have induced a crazy amount of front roll???
thanks
Paul - stunned...
thanks
Paul - stunned...
- Has thanked: 10 times
- Been thanked: 448 times
check out the last post in the thread bimdapogs linked to in his previous post. It allowed for some roll to ensure the front wheels stayed in contact with the ground. A roll bar is necessary to keep it from flopping around.
I tried Ultima universals in the front and the axle is too short. If you have a minute could you measure the lenght of the axle? I want to buy a set but I I must make sure it's the right one.Bimdapogs wrote:It has Kyosho's in the front (from the Lazer/Mid, I think), and RC10 in the rear. Mine came with the mods when I got it.
I understand from your pict that you are not using the oneway bearings in the front?
Forgot to ask. Do you use a cross pin in the front to hold the wheel?
- Lonestar
Ha - found it, thanks.jwscab wrote:check out the last post in the thread bimdapogs linked to in his previous post. It allowed for some roll to ensure the front wheels stayed in contact with the ground. A roll bar is necessary to keep it from flopping around.
That's why one-ways and spools work... rear swaybars help too that's funny, when I looked at the pic I thought "my god this must be working like a front monoshock"...
Technology has come quite a way, eh?
Paul
I'll measure it up for you when I get home tonight. This setup still uses the one way hubs, it just rides on the axles. There is no cross pin.AYKBOBCAT wrote:I tried Ultima universals in the front and the axle is too short. If you have a minute could you measure the lenght of the axle? I want to buy a set but I I must make sure it's the right one.Bimdapogs wrote:It has Kyosho's in the front (from the Lazer/Mid, I think), and RC10 in the rear. Mine came with the mods when I got it.
The axles are almost too short, you can see here it almost didn't touch the nylon part of the nut. I personally don't know how it held up during races, it already had it when I got the car..
Mike Dunn may have used different axles. His look different. And I think I remember he mentioned in this thread he made custom unis.
http://www.rc10talk.com/viewtopic.php?f=7&t=14385&start=30
The previous owner of my radiant might have just tried to copy Mike's and went with what he had (he had a few Mids and a Lazer ZX).
- 2506 Views
Last post by besty22
- 45 Replies
- 6402 Views
Last post by Hcp22
- 1144 Views
Last post by markt311
- 110 Replies
- 21636 Views
Last post by JK Racing
- 1740 Views
Last post by mrlexan
- 937 Views
Last post by Badmuthatrucker
- 2232 Views
Last post by Asso_man!
- 24 Replies
- 4737 Views
Last post by prp
