Vintage Traxxas RUNNERS only
Re: Vintage Traxxas RUNNERS only
Old chassis wore out.Making ready for 17.5T sensored motor, 45amp ESC.
For some reason I cant get the MIP 08106 axles to fit. The axle shafts are too long and when the suspension compress it bottom out they hit the diff.
Thank you so much yes that was the problem. Now they fit!jwscab wrote:Looks to me like you have too much negative camber which could be causing the problem.
[youtube]yV3fuRiHWQA&feature=youtu.be[/youtube]
Was having problems with the new parts on the track for a couple of packs but now hope to have the bugs sorted out n adjusted.
Does MIP make a ball diff that fits an SRT? If so has anyone tried it?
The one for the Rustler/Slash/Stampede/Bandit fits.
[youtube]vCIQbJ14GZg&feature=youtu.be[/youtube]
Testing out a different combinations of tires. This set is proline lugnut rear with proline pro-65 front.
I think the lugnut tires will do better in dry conditions. For the wet stuff I think the mini-pin is a better choice.
[youtube]rHCwlOwObK0&feature=youtu.be[/youtube]
Mini-pin / pro-65
also added some fresh dirt clay to the track
Mini-pin / pro-65
- dave00beer
- Has thanked: 9 times
Very cool!
Looks like your SRT runs pretty darn smooth there, and holds that track quite well.
Ever since I switched to the AE gears I've been getting loads of rocks and dirt crammed into the gears.
It makes loud clicking noise when the gear hits the little rocks...
I think I might switch back to the traxxas clutch gear setup which worked fine before.
This video was shot after going around the track like 3 times. That much dirt and rocks got wedged up that quick.
[youtube]OtKHsri39kk&feature=youtu.be[/youtube]
Thanks dave! Ya its starting to stick pretty good.dave00beer wrote:Very cool!
- 280 Replies
- 19734 Views
Last post by klavy69
- 371 Views
- 775 Views
- 658 Views
- 984 Views
Last post by terex
- 2098 Views
Last post by Momo5
- 14962 Views
- 1609 Views
Last post by 3trxvintage
Users browsing this forum: No registered users and 15 guests
