Rc10 short arm/ 6 gear setup and race discussion
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
Re: Rc10 short arm/ 6 gear setup and race discussion
13/54 yep, 32 pitch. I dont have a 12 or I would drop a tooth. Motor gets a bit warm after a 7 minute race. I really should go back to 48 pitch, but I am resisting.
I snagged quite a few 54T spurs from Peg before I left. Maybe I'll give 32p a try. Maybe my spurs will last longer.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
^+1
I need to set my gear mesh pretty tight due to the large amount of topshaft play. I'm tempted to switch to 32p. With looser gear mesh it might even be more efficient.
PM me your address and I'll send you one. I'm pretty sure I grabbed 3 or 4 of the 54T spurs.
85Edinger wrote:^+1
I pulled my 6 gear trans out of my RC10 box and pulled it apart and cleaned it. I put it back together, adding black lube to all the gear surfaces (I do this in my Stealth's and they are smooth and quiet). I grabbed my 32p spurs and it turns out they are 48T and not 54T. I went ahead and built the diff with one anyway and am going to order up a 11T pinion for my 27T brushed motor. If I get really ambitious, I'll start rebuilding the original short front shocks.
- JK Racing
not sure you can get an 11 to a 48...before buying the pinion, see how close you can get the motor.
That's good info, thanks. I just looked on Ebay for a 54T gear and couldn't find one. Are they super rare? Is there another brand I can use?
- Has thanked: 824 times
- Been thanked: 2419 times
RJ Speed 54t works great and looks the part too
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXLP1&P=7
Factory Works website
Does that use the same size diff balls?
Yup regular old 1/8" balls
Thank you, sir. That helps a ton. I now have a $250 list of parts I want to buy. I can see that this will be a slow project.
Hi everyone.
This is a great thread. I have a box-stock A stamp car that has been sitting in pieces for a while now. It used to belong to my brother, but he gave it to me when he moved in with his then-girlfriend-now-wife. My old RC10 was sold off when I was in high-school in the early 90's. I really wish I had kept it. It had a graphite chassis, MIP metal gearbox, and one of the Parma Eagle bodies. Such is life.
Anyway, I am thinking of getting the gold-pan rebuilt and doing some racing. I have a newer Tamiya TRF201, but the new cars just don't do it for me as much. I guess I am getting old. Right now the gold pan is box-stock. I am collecting parts, but want to keep it pretty original. Do you all have any good suggestions for a good starting setup? Also, what springs (part numbers if you have them) are you guys running?
JConcepts Rips 1.9" front wheels and tires
JConcepts Double Dees 1.7" rear wheels and tires
Associated bell-crank steering
81t 48p spur gear
?? pinion
27t stock motor
4200 lipo standard (non-shorty) pack
Protech body
Associated 5.5" high downforce wing
Am I missing anything? What springs/shock oil would you guys suggest as a starting point? Any suggestions on the pinion gear? I am new to setting up gold-pans, so any help would be awesome.
I race in JK's neighborhood and my local track is outdoor clay (Freedom Park, Camaillo).
Thanks!
81t 48p spur gear
?? pinion
27t stock motor
Protech body
Thanks!
So I've got the old 6 gear out again and am going to take a swing at getting it's handling up to par. I've been running it the last couple of weeks with the standard kit tires and a slowish silver can motor. I'm running silver springs all around and 30 wt (I think) all around. I mostly run around in the street and at the park. I've decided a couple of things. The kit tires are rubbish on the street (which makes sense). The fronts are too narrow and really don't offer any grip on the pavement. I could go with the JConcepts tires/wheels, but those would wear out super quick. The issue I'm having is the front pushing and I just can't seem to get the front suspension smooth. Maybe I am just not using thick enough oil. My only solution is go to back to 2.2's. I wish someone would offer up something street worthy in the standard tire size. I ordered up a fresh set of wheels and Traxxas Anaconda tires. I've got all sorts of springs available to play with and 25, 27.5, 30, 32.5 and 35 wt oils.
Lastly, I love running this car with 32p gears. Surprisingly, the transmission is very smooth. I'm currently running a Tamiya Torque Tuned 25T motor, geared 13/54.
- Has thanked: 750 times
- Been thanked: 26 times
Hi Ca-rj,
With your 6 gear are you running the black idlers?
I believe the re-release idlers are made from the same material as the black ones.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDSYG&P=7
I have built two or three 6 gears and you can definitely tell which one has the black idlers.
I also did the RCCA out drive bearing mod, all up it spins like a stealth
Dave.
Dave.
Hi,
With the handling I built my buggy using the CE and Worlds manual, I am using silver springs front
and rear, with the shock shaft spacers as per the CE manual.
That should give you a neutral well handling car, tune from there!
I am running B2/3 2.2 tires and rims, you should see the thing fly, under power the nose comes up
but she is very stable.
Cheers, Dave.
Cheers, Dave.
- 1997 Views
Last post by GeekSpeed
- 24 Replies
- 2435 Views
Last post by JK Racing
- 118 Replies
- 29700 Views
Last post by Medved
- 990 Views
Last post by carloco8
- 847 Views
Last post by bgruen
- 1443 Views
Last post by trek
- 740 Views
Last post by Synergy
- 1322 Views
