Countersink
- Grizzly.RC10
- Been thanked: 10 times
- Has thanked: 823 times
- Been thanked: 2419 times
Re: Countersink
4-40 is 82*
8-32 is 100*
8-32 is 100*
Factory Works website
- Grizzly.RC10
Re: Countersink
Ok for the angle but what diameter size 1/4, 3/8 ? (for exemple ,i founded : 3/8" 100 DEGREE 6 FLUTE CARBIDE COUNTERSINK )gomachv wrote:4-40 is 82*
8-32 is 100*
Thanks
- Has thanked: 29 times
- Been thanked: 66 times
Re: Countersink
Arrrgghhh,
this is SO frustrating!! I was aware that the 8-32s are 100°, but I assumed they all were 100° or the rest at least 90°.
That's what happens when your head is metric I guess.
At least Home Depot has 82° in stock.... I just received my 100° yesterday
*** POWDER - KING ***
- Has thanked: 10 times
- Been thanked: 447 times
Re: Countersink
you'll find that the 100 degree #4 screws fit beautifully in the chassis bottom, almost like they were countersunk for 100 degree screws. I'm pretty sure they were, and associated used 82 degree screws by default. either that or the countersinks were not sunk enough to allow 82 to be flush.
I have a bunch of aircraft stainless 100 degrees I use for most builds using rc10 gold/black pan, and most graphite as well. I hate how the stock 82 don't sit flush (and rust)
Re: Countersink
Yes, but since I converted a graphite chassis to mid motor, I need both countersink drill bits, 100° and 82°. Thinks would have been simpler iff all used the same angle.
I assume that the original tub chassis is too thin for the 8-32 screws to have a 82° or 90° countersink. The flatter 100° does not have this problem.
At least I'll have the correct bit to make all screws sit flush now.
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
Re: Countersink
Yeah, I always assumed they used the 100-degree 8-32's because the chassis material was too thin for more "normal" countersink angles as well.
