Dated comments.
- rnoswal3434
Dated comments.
Is there a way to make the most current comment come up first? Kind of a pain to try to go to the last page, of many, in some cases to see the latest comments. If there is, let me know. but I understand that if "this is the way", lol then will just deal with it.
Russ
Russ
- Has thanked: 825 times
- Been thanked: 2434 times
Re: Dated comments.
I click this thing and it takes me to the last comment.
Factory Works website
- rnoswal3434
Re: Dated comments.
I found a way. At the bottom of the page of posts there is a box with an arrow in it and lines large to small. Clicking on that you can have the posts show up ascending or decending by date. I just changed it and I like it a lot better now, especially on posts with over 50 or so pages. But either way is easy, it's just the way mos of the other forums I have used over the years do it.
Thanks
Russ
Thanks
Russ
- rnoswal3434
Re: Dated comments.
Apparently though it only works only with the topic you are currently looking at, not all of them, sigh. Oh well
Russ
Russ
- rnoswal3434
- Lowgear
- Has thanked: 78 times
- Been thanked: 604 times
Re: Dated comments.
If you check out your User Control Panel, there's a lot of settings you can customize to your preference.
Here's the steps to change the direction of posts:
User Control Panel--> Board preferences--> Edit display options--> Display post order direction--> Descending
Don't forget to submit any changes you make.
- rnoswal3434
Re: Dated comments.
Thanks!!! I got it! Was too easy if I would just look! I appreciate the help with that and I did hit submit. It works!
Russ
Russ
Users browsing this forum: DotNetDotCom.org [Bot], Halgar and 1 guest
