Optima Tires......
CNA75
Optima Tires......
Post by CNA75 »
All - in light of recent prices on EBAY for NIP original OT-30 optima tires (unbelievable! :shock: ), I have decided that I will keep the ones that came with my NIB kit unused for the shelf and try to source some cheap alternatives should I decide to run the car.
Can anyone, therefore, recommend some readily (or at least more readily) available tires which fit the original optima rims? I'm looking for full width 4wd spiked tires.....
Thanks in advance.
mikedealer
Re: Optima Tires......
Post by mikedealer »
well, 1.6 tires fit, so you should be able to find some RC10 rear Tires, not readily available per say, but cheaper than $132 lol
i dont think there are any 1.6 tires readily available, unless from tamiya re're's like the frog/buggy champs etc, those are 1.5 but should fit
uzzi
Post by uzzi »
Change both rim and tires to run....problem solved :D
CNA75
Post by CNA75 »
uzzi wrote:Change both rim and tires to run....problem solved :D
Any suggestions, Chris, as to what rims/tires would fit (my knowledge is somewhat limited when it comes to Kyosho)? I'd really like some 5-spoke tires like these perhaps: http://www.tamiyaclub.com/trades_model.asp?cid=85782), but iwould be nterested to know about any other viable alternatives...
uzzi
Post by uzzi »
I am pretty certain those are HPI 3033 Super Star Wheel 57x35mm...based on those sizes 2.2 tires should fit on them but am uncertain of the offset (looks ok however).
I am pretty hazy with my Kyosho stuff but I think you would find the rims from Optima-Turbo Optima-Optima Mid and rear Ultimas are compatible in offset....they are however in 2 inch sizes (use CAT tires). You could try looking for Trinity wheels to fit 2.2 tires (can't remember the part number)
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
hotshot re-re tires are planty available
CNA75
Post by CNA75 »
Mr. ED wrote:hotshot re-re tires are planty available
That presumably means those Lohas tecnacraft look-a-likes will fit?......I've been waiting for an excuse to get a set of those... :mrgreen:
Mr. ED
Post by Mr. ED »
erh, no
The Lohas are 2.2 inch, but yes you could fit those rims to your optima fur sure and with their adjustable offset they'd be a great choice.
mikedealer
personally i like these tires
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAHL7&P=7
they are low profile, i have them on my ultima build originally
m_vice
Post by m_vice »
What about these: http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000308206&I=TAMC3000&P=K
I read somewhere that they would fit my old Turbo Ultima wheels. But i am not 100% sure.
uzzi
Post by uzzi »
You are going to run those alloy rims? :shock:
Finding tires are not the issue but rims to suit would be.
Brandon G
Post by Brandon G »
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
I run Lazer ZXR/ZX5 rims. They are 2.2inch and allow me to used modern tyres to suit track conditions. :D
-Jason.
Still known as- bormac
Mr. ED
Post by Mr. ED »
I think the offset on these 2 is too small for the front: probably causing interference between the rim and steering knucle.
The original ZX5 front rims are set out further and work indeed.
CNA75
Post by CNA75 »
bormac wrote:I run Lazer ZXR/ZX5 rims. They are 2.2inch and allow me to used modern tyres to suit track conditions. :D
Thanks, Bormac. Do you have a link to the wheels you are referring too (my Kyosho knowledge is very limited, I'm afraid)?
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarBing [Bot], No User AvatarMojeek [Bot] and 1 guest
