Tamiya Tyrrell P34 6-Wheeler - 1977 Argentine GP - 2022 Reissue
The place for all things re-release Tamiya.
GreenBar0n
Has thanked: 1270 times
Been thanked: 860 times
Re: Tamiya Tyrrell P34 6-Wheeler - 1977 Argentine GP - 2022 Reissue
Post by GreenBar0n »
RogueIV wrote: Mon Jul 15, 2024 8:58 pm If you're polishing it you'd want the Gloss one. [edit] missed the part where you said you already wet sanded.
There are (5) cans of TS-15 Blue on this body, the chances of sanding through the base coat are next to none :D. I'll definitely get this thing as smooth as can be with the 3500 sponge, before adding the clear coat.
Have all the compounds and cloths for polishing.
Will order some TS-13 Gloss Clear now. Glad I waited before putting the TS-80 on.
Thanks!
RogueIV
Has thanked: 2135 times
Been thanked: 1099 times
Post by RogueIV »
GreenBar0n wrote: Mon Jul 15, 2024 9:06 pm
Thanks!
It's possible to make flat paint shiny but boy is it not the easiest, especially if there's small details you can't really polish too much. It would make for an uneven finish.
GreenBar0n
RogueIV wrote: Mon Jul 15, 2024 9:15 pm It's possible to make flat paint shiny but boy is it not the easiest, especially if there's small details you can't really polish too much. It would make for an uneven finish.
I've heard that your supposed to put the decals on, and then clear coat over them too, to get the ultimate in scale look. Have you tried that trick yet?
Thanks again!
RogueIV
Post by RogueIV »
GreenBar0n wrote: Mon Jul 15, 2024 9:41 pm
Thanks again!
I personally haven't, but it does make sense.
GreenBar0n
RogueIV wrote: Mon Jul 15, 2024 9:48 pm
GreenBar0n wrote: Mon Jul 15, 2024 9:41 pm I've heard that your supposed to put the decals on, and then clear coat over them too, to get the ultimate in scale look. Have you tried that trick yet?
Thanks again!
Fender does this with their head stock decals, to make the decals look painted on. Looking forward to trying it on the P34.
Thanks!
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Post by 1911Colt »
I am no paint man by any means, but I'd swear Suzuki sprayed clear over the decals on my GSXR fuel tank. There is no edge to them at all.
I admire your tenacity with this kit. I really thought I wanted one, but now I know I am not up to the task. :lol:
GreenBar0n
1911Colt wrote: Tue Jul 16, 2024 7:46 am I am no paint man by any means, but I'd swear Suzuki sprayed clear over the decals on my GSXR fuel tank. There is no edge to them at all.
Thanks! I'll never do another ABS body without primer first, it helps stop the runs and the uneven look to the paint. This was the first ABS body I've done, fortunately I can just sand it and keep starting over until I get it right.
I saw a guy on the Tamiya web site took his '77 P34 out to the track, hit a wall and broke the body his first time out. There are no body replacements sold for this kit, not sure I'll ever drive this one far, or fast, so it needs to look really good on a shelf :D.
GreenBar0n
I've been carefully studying the best way to finish this model, and found these excellent how-to articles at Tamiyabase on how this is all supposed to be done:
https://tamiyabase.com/articles/54-painting/126-part-8-spraying-paint-a-clearcoat
I'm not going to clear over the decals, apparently you do that when the quality of your decals are poor. Tamiya decals are about as good as you can get, and don't benefit from a clear coat, unless you want them to look painted on.
I'm going to clear only the body and wing, or all the TS-15 Blue parts, and then add the decals.
Got the body free of orange peel and smoothed out to 3000 grit.
The wind is really strong today to try and spray the clear, might have to wait until tomorrow, but this project is going forward asap.
GreenBar0n
Got the clear on, going to see what polishing it does.
GreenBar0n
TS-13 Gloss Clear is great, it won't fix a bad paint job, but it puts that wet look all over it, which sometime you can get with just the paint, but this makes it even.
Went too much on the side and it dripped.
Have already polished the drip out with 3000 grit wet sponge, but now I need another can of TS-13 to finish this.
Was so close to being done. Ordering TS-13 now.
GreenBar0n
TS-13 sprayed.
Will wait a week for this to fully cure. Then learn how to polish.
GreenBar0n
Got the Coarse polish applied, it removed the orange peel and uneven surface. Might need one more Coarse polishing.
Hoping to complete the Fine and Finish steps tomorrow.
GreenBar0n
Made it to the Fine and Finish polishing stages. Should be able to complete this one, hopefully tomorrow.
Dadio
Has thanked: 2757 times
Been thanked: 2250 times
Post by Dadio »
This is going to look better up close than a real one :!:
GreenBar0n
Very kind of you to say, thank you! I'll try not to mention the areas that I know are a bit messed up, and hope no one notices them :lol:
Getting started on the Finish polish now.
Return to “Tamiya Re-Release Forum”
