#6002 - RC10 Worlds Car Kit
Patiofurnituregt
Re: #6002 - RC10 Worlds Car Kit
Post by Patiofurnituregt »
Orange wrote:
popboy905 wrote:Hey Tim, any chance 3 degree inner mounts are going to be available with the worlds car, or will they be released as a option?
I second this question!
Or should we continue to horde any T2 3 degree mounts we can find? :)
Continue the hording! Since they aren't on the world's car, it is likely not to be re-produced. Sorry guys...
However, that could change if vintage racing really takes off!
Tim Tunnermann
Team Associated Design Engineer
Team Associated | |Reedy | XP Digital | JConcepts | Futaba | Makita | Kicker | LiveRC
Patiofurnituregt
jwscab wrote:yeah, I believe 12mm and 10mm. the difference boils down to giving you a little finer adjustment range for a given spring and damping oil due to higher volume of oil/larger piston and larger diameter spring.
To help elaborate:
The big bores are 12mm and the V2's are 10mm. Big bores offer a more plush ride because the shock shaft makes up a smaller percentage of the oil volume displaced when compressed (which can reduce the 'pack' feel). Additionally, since the oil volume is much higher and given the same amount of air in the shock (because it's emulsion), there will be less cavitation and shocks will stay more consistent. Also, the larger oil volume makes them less susceptible to changing viscosity due to heat build up.
The big bore springs are much better because they are simply put 'better designed', particularly when compared to the rear springs. The old rear springs were too long given their diameter and as a result they become 'unstable' and buckle. When the spring buckled with small bore springs they would rub on the shock body which causes additional resistance and an unintended side load to the shock.
It is pretty amazing now days building up a new B5 shock and comparing it to the RC10 shocks, the difference in how free and smooth the new shocks are is amazing. We've certainly come a long ways!!
Tim Tunnermann
85Edinger
Post by 85Edinger »
I'm tempted. Refilling all the oil that left my bottom loaders has become normal maintenance between heats.
markbt73
Post by markbt73 »
ca-rj wrote:You might be able to do the middle option and just run the V2 shocks with big bore springs, though I wonder if the springs will be too long for the shorter .71 front shocks (those are B4 shocks in the picture).
Hey, I recognize that noseplate!
stulec52
Post by stulec52 »
if you ever went from thinking an SRB or Kyosho Scorpion shock was the greatest thing possible to an original RC-10 shock, then you'll know how far Associated took shock design at the time.
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
little ot but i noticed a HUGE change in handling when i put hot bodies d8 shocks on my… slash4x4… 8)
big bores on an old buggy just look wrong to me. kinda like somebody putting 22's on an old camaro.
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
That's how I feel about 2.2's on the old buggies.
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Post by Y'ernat Al »
badhoopty wrote:...kinda like somebody putting 22's on an old camaro.
:lol: That make me check around to see if I agree with you. Yep. I agree, even if you do match them to your interior..
- Brian -
My Gallery
popboy905
Been thanked: 10 times
Post by popboy905 »
85Edinger wrote:I'm tempted. Refilling all the oil that left my bottom loaders has become normal maintenance between heats.
gotta have something to do between heats.... since i no longer have to clean my comm and brushes
kaiser
Post by kaiser »
I never had problems with ae's bottom load shocks. Losi on the other hand was brutal back in the day.
85edinger, maybe it's time for some top loaders.
I got some .56's you can try if you want to stay true to your short arm car. You'll have to source some rears though.
85Edinger
Post by 85Edinger »
I really appreciate the offer on the top loaders, I'll think about it. In the meantime, maybe I'll try rebuilding the old ones to stop the leaking.
My car's no longer a short arm btw. I basically converted it to a CE (but still with. 56 front shocks) do it could keep up at my local track. The car is great, I'm still the limiting factor.
Now that the Worlds is out though, I'm tempted to scrape together some money and buy one. Then I could put the original parts back on my short arm, buy some re-re tires, and run it in Classic. I have enough money saved, and it's very tempting.
Orange
Post by Orange »
I put big bores on my RC10... They look right at home on there! And if I ran V2's, they would also get Big Bore springs adapted on them. Talk about rubbing springs! Not a fan of having to sand them to make them work semi right. I would run older kyosho springs before that happened. ;)
(Let the comments commence) :lol:
Sean Sanchez
Gallery:
My feedback
janaya
Post by janaya »
I have a spare set of big bores and decided if I don't use them I will use big bore springs on the V2's.
Javier -
Orange
Post by Orange »
I have several sets of those of the T2 mounts.... They rarely (If ever) break. I have never broken one anyway. so I'm good for a long while. But I still buy them when I see them.
Sean Sanchez
Gallery:
My feedback
janaya
Post by janaya »
Do the T2 versions not have the second set of holes for extending the wheel base?
Javier -
