well I have a few things left tell i can run my gold pan here is my question
what spur and pinion ratio should I run? here is my setup 6 gear trans, ruby 16 turn brushed, novak fusion, 2200mh battery
a link would be awesome
thanks guys,
almost there
- Been thanked: 12 times
Re: almost there
The six gear trans is a fairly high ratio and that is a relatively low turn motor compared to what was regularly used in that era. I would start with the smallest pinion/largest spur you can fit, especially if you are using modern tires which are a bit taller than the originals.
Re: almost there
I'll give it a try and go from thereaconsola wrote:The six gear trans is a fairly high ratio and that is a relatively low turn motor compared to what was regularly used in that era. I would start with the smallest pinion/largest spur you can fit, especially if you are using modern tires which are a bit taller than the originals.
Thanks for the help
RAWPWR
Users browsing this forum: Tbot [Bot] and 89 guests
