Would like to know if the motor needs to have the condenser that came with it, the motor is a lemans 240st.
Found the car at my Dads place and remembered that I had started to build it, some 20 years ago.
kyosho Motors with brushes for turbo optima mid se
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Re: kyosho Motors with brushes for turbo optima mid se
Capacitors?
It shouldn´t be a problem to run Your motor without capacitors.
To my knowledge, its only to eliminate electric interference.
So if You don´t receive any complaints from neighbors or fellow racers - it´s no problem.
Gone fishing
- Been thanked: 325 times
Actually, those are more or less a required item, as Dennis said, to reduce interference--but not for your neighbors, for the motor itself. Electrical interference can make the motor very glitchy, spastic, coggy, etc. Definitely solder those on, especially if you're using a radio & receiver from the same era.
- Been thanked: 100 times
Yes, use the capacitators. They are supposed for removing interferences, but not for the motor, more for the radio. The maybe strange bahaviour of a motor is the result of glitches/interferences of the radio.
Thanks guys, just need to get a new one this one is broken. What value do i need to get?
- 3185 Views
Last post by Bo Wallen
- 2815 Views
Last post by tintin74
- 4270 Views
Last post by Jester_The_RC_Guy
- 1333 Views
Last post by Lonestar
- 1330 Views
Last post by TomEG
- 49 Replies
- 8584 Views
Last post by nvxwax
- 1287 Views
Last post by TomEG
- 253 Views
Last post by SPA240WS
