Masami's crooked steering.
General info, Q&A.
SteveK
Post by SteveK »
This has bugged me since 1991; on Masami's Reedy Race of Champions winning car, he used Yokomo bellcranks in lieu of the stock RC10 steering. If you looks, the steering appears canted to the right, and the left tie rod is shorter than the right. Any ideas why?
Re: Masami's crooked steering.
the steering is to the right because the bellcranks are to the left.
as for the turnbuckles, the pic seems to be taken on a slight angle which could explain the difference between left and right.
tamiya
Been thanked: 9 times
Post by tamiya »
just the angle of the photo methink; the tyres aren't really dead straight
everything is probably straight except for servohorn,
that's probably not dead 12o'clock at neutral
SteveK
Post by SteveK »
If you look at the steering links, you can see the left one is shorter when you compare the nut and exposed threads. I don't think it's the camera angle because the camber links appear to be the same length.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Looks like the unthreaded portion of the left steering tie rod is longer than the right's...which is why more thread is showing on the right tie rod to the inside of the nut.
SteveK
Post by SteveK »
The whole page, uncropped.
the picture is on an angle. the shock tower covers the nose tube on the left, doesn't on the right. there's also no guarantee the the chassis is sitting level to the ground, or that one of the front arms is higher than another.
Bottom Feeder
Has thanked: 13 times
Been thanked: 25 times
Post by Bottom Feeder »
That's what I always liked about Masami's cars. They always looked like a well-tested and well-used patchwork of spare parts that obviously worked very well together. :lol:
Look at those hacked nose brace tubes!
SteveK
Post by SteveK »
Yeah, you can always tell something like a race car (real or RC) or memorabilia from a movie is the real deal when it is all worn and beat up looking.
Jirka
Has thanked: 33 times
Been thanked: 24 times
Post by Jirka »
It would have not been the first time when Masami used non symmetric setup. His "RC10" at 1989 worlds did have more front spring preload on left (right hand side in this picture, since it is taken from front).
Masamis rc10 1989 worlds.jpg (16.17 KiB) Viewed 2181 times
BTW: On all "this is Masamis 1989 worlds winning 2wd car" documents like links below didn't have this non symmetric setup no more for some reason, but on all magazine pictures taken from that race it can be clearly seen.
http://www.rc10talk.com/viewtopic.php?f=35&t=5500
http://www.rc10talk.com/viewtopic.php?f=81&t=1002
Jirka
EDIT: Forget to add the picture :oops:
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
scr8p wrote:the steering is to the right because the bellcranks are to the left.
that cracked me up :mrgreen:
Has thanked: 355 times
Been thanked: 470 times
:lol: I think the "steering" situation is being way over-analyzed, I've heard two credible and perfectly viable answers, that have been shot down because, well...I don't know why :lol:
It just is.....
i should've said....... wheels to the right, bellcranks to the left. :wink:
Lonestar
Post by Lonestar »
btw I never noticed before that ET was using deans 4-pins plugs... which were my plug of choice even late into the 90's :) :) :) At least I share something with Masami :lol:
SteveK
Post by SteveK »
It just is.....
I dunno why, it just bugs me LOL The steering links are clearly different lengths, and I guess I just can't comprehend something like that on the car or such a high level racer.
