Removing CA glued tyres from wheels using Heptane debonder
- LosiXXkid
Thought I'd just post a link here to my thread detailing the 100% intact and clean removal of CA glued tyres from wheels using a Heptane based de-bonder.
http://www.rc10talk.com/viewtopic.php?f=27&t=36724&start=30
- littleVETTE
- Has thanked: 6 times
- Been thanked: 10 times
Re: Removing CA glued tyres from wheels using Heptane debond
outstanding. those are some awesome results.
Awesome, just bought some to test over the weekend!
- LosiXXkid
I had no idea about the results before I had a go with the de-bonder so I'm happily surprised at the outcome but I'm actually more surprised that I couldn't find any mention of it being used for this purpose anywhere....
Everyone else appears to go with either boil, bake or acetone!
- LosiXXkid
I look forward to hearing about/ seeing your results!fakiee wrote:Awesome, just bought some to test over the weekend!
Me too, i will try and post my results. I've got a couple of wheel sets to get throughLosiXXkid wrote:I look forward to hearing about/ seeing your results!fakiee wrote:Awesome, just bought some to test over the weekend!
I used boiling before with some results, but it took the dye out of the wheels. Can wait to try your method. Good find on the Heptane!!
- Been thanked: 325 times
I tried boiling & freezing; neither worked very well. The acetone fume method works great, but you need to leave it sit in a sealed bag for 24 hours.
- LosiXXkid
With the de-bonder you've just got to allow it time to work. Once it has softened up the hardened CA, the tyre comes right off the wheel. Then it's just a case of cleaning everything up which is actually the most time consuming part but it's certainly worth the effort.Coelacanth wrote:I tried boiling & freezing; neither worked very well. The acetone fume method works great, but you need to leave it sit in a sealed bag for 24 hours.
That sounds exactly how the acetone method works, just faster. And faster is better.LosiXXkid wrote:With the de-bonder you've just got to allow it time to work. Once it has softened up the hardened CA, the tyre comes right off the wheel. Then it's just a case of cleaning everything up which is actually the most time consuming part but it's certainly worth the effort.Coelacanth wrote:I tried boiling & freezing; neither worked very well. The acetone fume method works great, but you need to leave it sit in a sealed bag for 24 hours.
- LosiXXkid
The thing for me that stands out with this stuff is that it doesn't evaporate like acetone does so you can actually work with it in small quantities.Coelacanth wrote:That sounds exactly how the acetone method works, just faster. And faster is better.LosiXXkid wrote:With the de-bonder you've just got to allow it time to work. Once it has softened up the hardened CA, the tyre comes right off the wheel. Then it's just a case of cleaning everything up which is actually the most time consuming part but it's certainly worth the effort.Coelacanth wrote:I tried boiling & freezing; neither worked very well. The acetone fume method works great, but you need to leave it sit in a sealed bag for 24 hours.
True, but it might end up being more expensive than a capful of acetone from a big 1L can of it. The fumes aren't going anywhere when it's in a sealed bag, so evaporation isn't an issue.
if you have standard rubber tires and nylon wheels, they are not easily damaged by acetone liquid. I recovered a set of yokomo 834b wheels and tires that had been spray painted blue, yellow, white and red(about 8 or 9 rims). stuck them in a zip lock bag a pair at a time with some acetone, swished them all around, worked the beads loose, and spend a bunch of time wiping down the goo and paint. those were pretty bad. So it depends on how bad the parts are, the composition, and how much time you have to work the parts. this everbuild stuff seems to work pretty fast from your pictures!
t
I've been using acetone to debond
1L at home depot for 9.99
Then go to the dollar store and buy a rectangular sealed container
Also bought some cookie cutters to place the wheels on top to try the fume method. In my experience it takes long with the fume method.
I found though if you don't need the inserts just let them sit in the acetone for 12hr and remove tire then flip on the other side do the same.
Thanks for bumping up this thread, I had not seen it and it's very helpful.
Scott
Scott
- Brandon G
I've been looking into sourcing heptane and found that the Coleman fuel has a high percentage of it. I need to stop and actually look at the ingredients to be sure.
Another source is Bestine thinner and solvent. It is 100% heptane and seems reasonably priced.
- 20 Replies
- 2239 Views
Last post by davidka
- 1278 Views
Last post by templeofspeed
- 1884 Views
Last post by Retro-RC.co.uk
- 935 Views
Last post by mikedealer
- 4675 Views
Last post by JosephS
- 859 Views
Last post by RedScampi
- 1103 Views
Last post by LowClassCC
- 1478 Views
Last post by 59burst
Users browsing this forum: Google Adsense [Bot],
LoboNYC and 1 guest
