5 link rear suspension question
bigmd
Post by bigmd »
Ok so I picked up a JrxT off eBay and realized later that it’s been converted to rear control arms. I assume with the control arms the links from the chassis are obsolete ? It still has the chassis posts . Does anyone have the part numbers for the rear links that would replace the arms ? And do I also need to replace the hinge pins at the bulkhead to go back to stock?
Thanks
RogueIV
Has thanked: 2129 times
Been thanked: 1095 times
Re: 5 link rear suspension question
Post by RogueIV »
the bulkhead hinge pins should be the same, unless they swapped out to RPM hinge pins that only have 1 E clip slot.
Rear links are A-2004, which covers 1 side.
You'll also need the lower shock shackle as well which is A-5001 (or A-5010 which has spring clamps too)
Also if is doesn't have the squared off rear pivot support, that's A-2002.
All this info is in the manual, which can be downloaded here: http://vintagelosi.com/ManualsGuides.html
bigmd
Post by bigmd »
Thank you sir. Also, the RPM .050 rear links are just a narrower version?
RogueIV
Post by RogueIV »
bigmd wrote: Sun May 18, 2025 3:09 pm Thank you sir. Also, the RPM .050 rear links are just a narrower version?
Yes they were used to give more toe in by replacing the front link.
bigmd
Post by bigmd »
Awesome . Thanks for the help and info.
Return to “Losi Forum”
