FX-10 question....
- highwayracer
- Been thanked: 7 times
Re: FX-10 question....
The FX-10 is pretty much a clone (with some differences) of a Tamiya Striker. So here are a few cars that use the same mounting system:
striker (1.7 wheel)
sonic fighter (1.7 wheel)
falcon (1.7 wheel)
grasshopper 2 (1.7 & 2.0 wheels)
super hornet (2.0 wheel)
fox (2.0 wheel)
wild one (2.0 wheel)
The 2.0 wheels are actually 2.0 for the rear and 2.1 for the fronts. They all use the 5mm x 11mm bearings in the front.
You can also use kyosho 2wd wheels as long as you use the hex adapter (on touring cars or the HPI adapter set). You'll have to use a 5mm x 8mm bearings for the front wheels.
hope this helps.
regards,
highwayracer
striker (1.7 wheel)
falcon (1.7 wheel)
fox (2.0 wheel)
hope this helps.
regards,
highwayracer
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
With the proper hex you can also go modern and use sand viper or desert gator wheels.
- Brandon G
Actually I have the wheels to fit FX-10, just wondering what else they might fit.
- mrlexan
- Been thanked: 12 times
Falcon, Fox, Wildone, Super Hornet, GH II..... anything with the 4 pin drive.
www.gojammedia.com
www.gojammedia.com
- 1337 Views
Last post by treehugger
- 2761 Views
Last post by stingerrray
- 1979 Views
Last post by teman
- 1976 Views
Last post by WillyThickfoot
- 714 Views
Last post by GAMMACRUSH
- 882 Views
Last post by Dr. Robotnik
- 915 Views
Last post by R Cane
- 876 Views
Last post by Erich Reichert
