Id help??
marcusj8826
Id help??
Post by marcusj8826 »
What frame is this.
It´s never used.
I found it in my fathers garage with an fresh K&B engine.
What i think is the front RC300 and the rear RC200 but with dual discs??
Thanks Marcus
Twiceblown351
Re: Id help??
Post by Twiceblown351 »
Its a RC250. But the fiberglass pan not suppose to be cut out like that. You can make the upper and lower pan out of G-10 fiberglass plate. I should have the template here. I should have the motor mounts if you don't have them. I know i don't have the gas tank.
Twiceblown= 93 F150 Lightning
393 and two turbos @ #10Psi
= 10.90@126 in street trim
marcusj8826
Re: Id help??
Thanks!
I just got a new tank and servo tray and some more small stuff.
But i dont have the motor mounts and the fwd body mounts.
Her is my last findings.
I dont know what it is??<br />LOLA?
LOLA?
Twiceblown351
Re: Id help??
Oh man you got the old tin fuel tank cool. The rear body mounts are the wing tubes. The front body mounts are just RC10 body mounts with white spacer under them. You can still buy the spacer that look the same at lowes. I think the bolts are a little bigger but i just drill them out or just use a smaller bolt.
I have to see if i have the motor mounts. I have the one for a OS max but the most likely not the same for the K&B.
Users browsing this forum: No User AvatarAmazon [Bot], User avatarRonbo and 7 guests
