What's the Trick to.......
- rc10johnny
- Has thanked: 15 times
- Been thanked: 34 times
Re: What's the Trick to.......
ditto. an old beatup and dull pair of sidecutters.scr8p wrote:i use a pair of side cutters to work them out, using the axle for leverage. works like a champ..... every single time.
- HotRodJosh
- Has thanked: 3 times
I use modded hog-ring pliers....
"I've got a fever, and the only prescription.....is more cowbell."
Pinstriping by Josh
Pinstriping by Josh
i side with ROH73 home depot sell a set of three nail punchs the smallest was made just for just this problem
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
Yep, sidecuts are the answer for me. Seems like the more you pry that little bugger out the easier it goes in next time. This was a real problem for me the first time I had to do it also Jay, back in 1986.badhoopty wrote:ditto. an old beatup and dull pair of sidecutters.scr8p wrote:i use a pair of side cutters to work them out, using the axle for leverage. works like a champ..... every single time.
This is all very interesting!
I have a pair of needle nose pliers that has a bend in the jaw. Typically I can grab the pin and push the jaw against the axle to lever it out. I think the punch is a good idea too.
Gary
- Has thanked: 28 times
- Been thanked: 957 times
if people...... when building the cars...... would just give the pins a little squeeze with a pair of pliers before installing them, they would go in and out very easy. they only need to be snug enough to not fall out when you pull the wheels off.
- LTO_Dave
- Has thanked: 46 times
- Been thanked: 225 times
And I thought I was the only person to have this much trouble with these things!
I hate them! Every pin in every axle I have has been difficult to remove.
I usually end up using a small allen-tipped screwdriver and a hammer to get them the rest of the way out. A small vise also comes in handy.
Another tool you could modify is a bicycle chain breaker by grinding the tip smaller.
I've found that grinding the tip off a finishing nail and using it as a punch works really well. If you don't grind the point off it may expand the roll pin making it even harder to get out. Its a cheap alternative to buying a punch that I see no other use for.
- bearrickster
- Been thanked: 5 times
I have a set of Roll pin punches I got from Mac tools or Snap On. but its just an RC10 just through it out and replace it with a Losi you will never have that problem again.
- mrlexan
- Been thanked: 10 times
Took the wife out to town today, so had a break from building/restoing, BUT I am OVER pulling those damn things out. I don't know how many I did...... TOO MANY!
www.gojammedia.com
www.gojammedia.com
mrlexan wrote:Took the wife out to town today, so had a break from building/restoing, BUT I am OVER pulling those damn things out. I don't know how many I did...... TOO MANY!
Pushing them out is easier
I just buy new parts. I have a huge shoe box full of nothing but axles and hub/bearing assemblies. WAAAYYYY easier! Oh and I eat rainbows and poop butterfies too. . -Jeff
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
DITTO!scr8p wrote:if people...... when building the cars...... would just give the pins a little squeeze with a pair of pliers before installing them, they would go in and out very easy. they only need to be snug enough to not fall out when you pull the wheels off.
Come and visit the stable
- Jeep-Power
- Has thanked: 29 times
- Been thanked: 21 times
I find they come out easily with a set of needle nose pliers-- just be sure to have the slot in the pin facing the tip of the threads-- this way when I squeeze down on the pin, to grab it, it also compresses the pin, thus allowing it to pull out.
regular pliers work well using this method. too.
If the slot is facing 'sideways', then yeah, it is a PITA!!!
- 448 Views
Last post by tulsa
- 1129 Views
Last post by Asso_man!
- 441 Views
Last post by Russ Winn
- 486 Views
Last post by aeiou
- 23 Replies
- 3518 Views
Last post by Dadio
- 954 Views
Last post by treehugger
- 2254 Views
Last post by vintage88
- 1559 Views
Last post by orangemazda
Users browsing this forum: No registered users and 19 guests
