Me too! But my black rear hub carrier just arrived from Towers! What a waste!scr8p wrote:metaldog - does the front evader wheels accept the 3/8" bearing, or are they metric? if i'd get a pr. of the nitro evader rears, i'd like to have a matching pr. for the front, too. that's why i'm asking.
B4 CVDs and tires
- PBR Allstar
after looking at the tower parts list for the evader I'm pretty sure it uses 3/8" bearings seeing as the front axles are 3/16". Wish I looked into this a little earlier, I just placed an order from tower yesterday.....scr8p wrote:metaldog - does the front evader wheels accept the 3/8" bearing, or are they metric? if i'd get a pr. of the nitro evader rears, i'd like to have a matching pr. for the front, too. that's why i'm asking.
- Has thanked: 28 times
- Been thanked: 957 times
i looked through the parts list too, but i didn't see anything that said they accept a 3/8" bearings. i'll just get a pair, they only cost $5.00. it's not like i've never wasted money on parts that don't fit.PBR Allstar wrote:after looking at the tower parts list for the evader I'm pretty sure it uses 3/8" bearings seeing as the front axles are 3/16".scr8p wrote:metaldog - does the front evader wheels accept the 3/8" bearing, or are they metric? if i'd get a pr. of the nitro evader rears, i'd like to have a matching pr. for the front, too. that's why i'm asking.
- PBR Allstar
i had that same assumption.PBR Allstar wrote:I was making that assumption based on the fact that in the parts list all the bearings I noticed were metric with the exception of some that were 3/8 x 3/16, and the axles have a 3/16 diameter. But then again, you know what they say about assumption....
like i said, i've spent alot more than $5.00 on parts that didn't fit what i needed them to. i'd eventually find something to put them on.
- Dr. Robotnik
parts
Amen brother, waste not, want not. I am a sucker for buying stuff just incase and then building a project round it.scr8p wrote:i've spent alot more than $5.00 on parts that didn't fit what i needed them to. i'd eventually find something to put them on.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
does anyone know if RC10T/GT rear hubs can be used with buggy axles? and if yes with which bearings (flaged/unflanged, size)?
I am asking this because I have black RPM rear hubs for the GT or T and would like to use them on a Ten... thanks for your answer, if any...
Come and visit the stable
are the rpm hub carriers you have the ones that use the 1/2" oversized bearings? scroll down a little in the link.Asso_man! wrote:does anyone know if RC10T/GT rear hubs can be used with buggy axles? and if yes with which bearings (flaged/unflanged, size)?
http://www.rpmrcproducts.com/products/assoc/rear.htm
in a stock asc hub carrier you's use 1/4" x 3/8" or 3/16" x 3/8" unflanged bearings. depending on what size axle your using.
- Asso_man!
yup, these are the ones I intend to use. So, if I use 3/16" x 3/8" unflanged bearings and B2/B3 CVD's it should be OK in a RC10 I assume?scr8p wrote:are the rpm hub carriers you have the ones that use the 1/2" oversized bearings? scroll down a little in the link.Asso_man! wrote:does anyone know if RC10T/GT rear hubs can be used with buggy axles? and if yes with which bearings (flaged/unflanged, size)?
- MOmo
Re: B4 CVDs and tires
Hmm part of me is wishing i would have kept some of my B3 spares before i traded it off.
In another thread, Im trying to restore one of my RC10s to race in a vintage class. I wondered if the newer parts from like a b4 and b2/3 would work so to eliminate the drag and possibility of losing a dogbone. I seem to recall upgrading my friend CE years ago with CVDs.
MOmo
MOmo
Did anyone ever acually fit B4 wheels on a tub RC10? If so what was the rear track like? The same?
Thanks,
G
Thanks,
G
I'm back! I was 'Northy' but my profile got screwed
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
I've been playing with this same issue myself. I picked up HPI hex adaptors and checked my ZX5/RB5 wheels last night, no go, too narrow. I may hop over to the local shop today and try a set of CRT .5 wheels. At least in pictures, the offset looks correct. I have one set of B3 rear rims NIB, but I know to race, I will need a few more sets. Especially attempting to campaign 2 different 10's out there...a graphite car, and a trailing arm car.
If it all works out, I will post some pics, if not, the search continues...
- templeofspeed
My LHS stocks the B3 rear wheels as replacements for the CRT.5. Shouldn't be a problem. IIRC the B2/B3 fronts are discontinued.
Someone also mentioned Duratrax Evader rear wheels, too. I don't know if they're 5mm or 3/16" though.
- 694 Views
Last post by rawpwr
- 20 Replies
- 2568 Views
Last post by adam lancia
- 1369 Views
Last post by stickboy007
- 1962 Views
Last post by 3trxvintage
- 1007 Views
Last post by janaya
- 817 Views
Last post by mk-Zero
- 685 Views
Last post by peetbee
- 900 Views
Users browsing this forum: Google Feedfetcher and 3 guests
