1994 YZ10 #3 and 4
Re: 1994 YZ10 #3 and 4
So you actually cut the tape when its on the shell? Carefully i guess?
As for your flames, after you do the base coat of the car, do yoi take the flame masking off and then do you colors by hand, ie do the out side red first, then orange then yellow ?? Sorry stealing all your secrets!
- stickboy007
- Been thanked: 17 times
Yeah. What I do is use a sharpie to draw the flames on the outside of the body, then apply masking tape. The sharpie shows through the tape and you can trace that with a razor to cut the tape. Then, for my standard scheme, I do black, then blue, then back it in white. Then I remove the tape and do red, then yellow, then back it in white.
Um whats a sharpie, like a removeable marker? And why do u back all your colors in white? Same reason as fluoro's?
Thanks again
Thanks again
- stickboy007
A sharpie is a felt tip marker, permanent black ink (doesn't matter if it's permanent, since you have a protective film over the body, and that's what you're drawing on. You can use a paper towel to scrub off the ink on that film if you make a mistake). I back everything in white to bring out the color. Otherwise, it looks dull.
Ahah. So i guess you have to be pretty careful when cutting the tape that you dont cut the lexan? Or does that no matter too much?
That 91 you mentioned in your opening thread...you didnt grab that if ebay a little while back from England? Carbon fibre chassis?
- stickboy007
Yes, you have to be careful not to cut the lexan. It's easier to do with a fresh blade, since you don't have to press as hard to make a clean cut.
The '91 Works was off of eBay in the UK, yes.
Ta
Dang I was looking at that one....! Was a good pick up...did it have the 91 chassis or was that fiberlyte one? Guy wouldn't post O/S...so I now have redirect address......anyway was a good pickup!
- stickboy007
It appears to be all original parts, with the exception of the battery braces, which are old Schumacher units.
dang again.....really wanted that one.! oh well you saved me some money.. So the 91 came out with a carbon fibre chassis?
So, out of morbid curiosity...whats behind the screen-name Flustorm?flustorm99 wrote:dang again.....really wanted that one.! oh well you saved me some money.. So the 91 came out with a carbon fibre chassis?
well nothing really just a couple of things that lined up....I was really crook for a couple of months with bad flu's (my lil girl just started childcare..more like bacteria school) was a wicked storm on here at the time and I like Wayne Gretzky!...I needed a handle for ebay so I just came up with that.
And stickboy??
And stickboy??
- stickboy007
Not many Americans out there who use stick radios and are smooth like Bond...haha.
So you can use a stick radio and chat up the ladies at the same time....smoooth... ...shakin not stirred?
- stickboy007
- 2638 Views
Last post by slotcarrod
- 38 Replies
- 3904 Views
Last post by stickboy007
- 1270 Views
Last post by buttmonkey1969
- 3826 Views
Last post by Ronbo
- 1508 Views
Last post by nikos2002
- 1883 Views
Last post by GeneralZod
- 1189 Views
Last post by Jirka
- 3541 Views
Last post by spru
Users browsing this forum: No registered users and 13 guests
