My lazer zxr with mip pro-x cvds
- Been thanked: 10 times
Sorry bngilies but they did fit and they do look good to....
Teamline hubs ballraced, mip cvds and 3racing alu rear hubs have the blue steering but has not been mounted yet...
mvh Isobarik
mvh Isobarik
- Has thanked: 135 times
- Been thanked: 23 times
Re: My lazer zxr with mip pro-x cvds
If you used them in the front like I think it shows, and they fit well. Should be able to fit them on a wide range of K-cars!! Cool.
Yeah they fit really well and they did have an inferno 10 kit also and those are similar to w5061
so you can take the pro-x axel and fit with the inferno bone and then you will have an cvd with pin hex like modern kyosho.
mvh isobarik
mvh isobarik
Have fitted law30 clampon wheel hubs and tr-15 yellow wheels almost forgot blue steering
mvh Isobarik
mvh Isobarik
- Has thanked: 7 times
- Been thanked: 41 times
Id like to build my zxr as a racer but worried bout replace of broken parts seein this rig has me thinkn about doin it. i like the use of newer parts. this build is lookn good.
Actually i doesent make the car wider the rims from tr15 is exactly the same as original wheels regarding offset but much more good looking ofcourse. Clamp on wheel hubs i have no numbers of measurement but i think it stays the same, the biggest different is when you have taken the axle out of the hub and are putting it together you dont have to hold the uj beacuse the hex is pinned and clamped to the axle.adam lancia wrote:How wide does that bring it out to isobarik? Looks good!
mvh isobarik
Yeah parts dont grow on trees but they do show up and some is still avaliable from kyosho and there is coming new stuff also from an entusiast that is making his own parts . Hard to find items are rear belts, Lazer zxr bodys and spurgear cover.Soncho Ponza wrote:Id like to build my zxr as a racer but worried bout replace of broken parts seein this rig has me thinkn about doin it. i like the use of newer parts. this build is lookn good.
pm me if you need any thing i have some stock and can point you in the right direction.
mvh Isobarik
just wanted to show you the running car....
i have bought the la118 so i can fit standard spurs and dont have to stick with kyosho stuff
The spur is avaliable from http://www.rwracing.co.uk and theay are machined and have the correct size 100t/48pitch
mvh Isobarik
mvh Isobarik
yeah thanks to duplicating mine.....Kyosho Fan2 wrote:http://Www.kamtec.co.uk will be selling one very shortly.
but i would like to have it now or preferably yesterday....
mvh Isobarik
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
isobarik wrote: The spur is avaliable from http://www.rwracing.co.uk and theay are machined and have the correct size 100t/48pitch
I'm using a 90teeth spur on mine, but that's the metric 0.6 module; comes from Tamiya
(forgot which model, TA05 perhaps?)
I kind of like the 0.6 module since I have a couple pinions in this module to run on my ultima and optima mid, it's just a bit stronger than 48 pitch and much smoother than 32 pitch.
Got to post my new body.
Missing some stickker dough.
mvh Isobarik
mvh Isobarik
- 1679 Views
Last post by jcwrks
- 20 Replies
- 2571 Views
Last post by adam lancia
- 995 Views
Last post by prp
- 2765 Views
- 1491 Views
- 1846 Views
Last post by RCveteran
- 1007 Views
Last post by janaya
- 817 Views
Last post by mk-Zero
Users browsing this forum: No registered users and 20 guests
