car goes fast,run time is less,wires get hot,esc gets hot.
- Banned Member
i was testing some electronics, i have a 12tooth pinion gear,52 tooth spur, a motor with "welcome to the machine"wrote on it,has the timing marks on it. dont know how many turns. also running a old novak 410 M1C esc. i put this system in a stock rc10 gold pan, 6 gear trans. goes FAST, run time is shorter than before, so i put this system in a stealth buggy, it goes even faster, run time still sucks, but it doesnt get as hot. im guessing the gearing is wrong. ive tried going with more teeth on the gears , it seems to run slower. any advice would be great
- slotcarrod
- Been thanked: 41 times
Re: car goes fast,run time is less,wires get hot,esc gets hot.
Your gearing is wrong, you want less teeth to the pinion not more. Try a 10 tooth pinion on the 6 gear tranny, if it's still to hot go to a 9t.
Rod Littau
- 927 Views
Last post by highwayracer
- 825 Views
Last post by terry.sc
- 1321 Views
Last post by mk-Zero
- 1923 Views
Last post by ChocoTaco73
- 21 Replies
- 1607 Views
Last post by Prince Steve
- 1914 Views
Last post by LurkingCAT
- 851 Views
Last post by Hcp22
- 525 Views
Last post by HS-YZ250
Amazon [Bot] and 2 guests
