MIP parts for losi
- Been thanked: 12 times
MIP parts for losi
I've been collecting parts for a while, there was a lot of interesting stuff out there from a lot of companies back in the early 90's
here is most of my collection of MIP Parts for the early losi cars.
Most notably missing is the yellow LB-2000 gearbox and a full CVD set.
I'm wondering what else they might have mader, besides replacement parts for the hop-ups
Re: MIP parts for losi
I actually had to double check myself when taking the pictures.
I have a car I built up with a NIP set of x-long rear and long front bodies. The used, loose bodies pictured are the xl/1.2" length and exactly the same as the ones on my car.
the long and short ones have more of a taper around the crown area and match each other better.
you can see the difference between the 2 shock tops on this car. Both pairs came out of the same package, also pictured(because I save all the instruction sheets and header cards together for each build).aconsola wrote:I actually had to double check myself when taking the pictures.
That's a stealthy looking JRX-Pro that I have not seen here before- you holding out on us Anthony?
I was going for the all black theme, but like many projects never got around to painting it.Charlie don't surf wrote:That's a stealthy looking JRX-Pro that I have not seen here before- you holding out on us Anthony?
The body is perhaps one of the ugliest aftermarket uggy bodies so you're not missing much
yup, here you go.GJW wrote:anthony can you show us how the slipper set-up goes together??
What kind of body is that on the Pro?
I saw how angular the side-pods were and for a moment thought that it was a Jammin Jumper body, but then I saw how far forward they extend ... which is too bad because I have been dying to know if the Jammin body will fit on a JRX2, Pro, or ProSE.
- mrlexan
- Been thanked: 10 times
I kinda like it. Is it from McAllister?aconsola wrote: The body is perhaps one of the ugliest aftermarket uggy bodies so you're not missing much
www.gojammedia.com
www.gojammedia.com
- Has thanked: 135 times
- Been thanked: 23 times
One more to add.aconsola wrote:I've been collecting parts for a while, there was a lot of interesting stuff out there from a lot of companies back in the early 90's
- 673 Views
Last post by Dr. Robotnik
- 411 Views
Last post by mrlexan
- 824 Views
- 450 Views
Last post by mikedealer
- 2088 Views
Last post by m2fit4u2
- 1571 Views
Last post by aip47-2008
- 1106 Views
Last post by paNX2K&SE-R
- 429 Views
Last post by HS-YZ250
