Novak esc
Novak esc
I am pulling my hair out with this thing...It has a neutral and speed adjustment...Novak Solid state speed control is what it says on the case...I can not get the throttle to work at all...I have steering...The only time the motor will spin is when I turn the esc on and off...And it only spins for a second or 2...I have messed with the adjustments on the radio (KO PROPO EX-5) and I messed with the neutral and speed on the esc and still nothing...Only when I turn the esc off and on is when the motor will spin for a second...What gives ????
- Been thanked: 22 times
Re: Novak esc
Try wiggling the switch see if get motor run more.If it does then replace or cut switch off solder wires together.And run it.don
- Has thanked: 824 times
- Been thanked: 2419 times
Re: Novak esc
Plug esc into channel 1 and the servo into channel 2. See if you can get the esc to work with the steering wheel and see if the throttle trigger works the steering servo. If you still don't have control you may have a bad esc. If the steering servo quits working you have a bad receiver. If both work, you probably had the esc plugged into the wrong channel (bat?)
Factory Works website
- integra22t
Re: Novak esc
Esc plugged into channel one will spin the motor...servo into channel 2 will turn the wheels using the throttle...I can't stop the motor from spinning unless I unplug it...
Re: Novak esc
Thanks for the help...I put the servo in channel 1 and esc in 2 and had to open the esc up because I couldn't get the tool to line up with the speed adjuster...After opening the esc up and adjusting the neutral and speed everything is working...Bad thing is if I have to adjust the esc I will always have to open the case up...
Re: Novak esc
Well, at least it's up and working
Re: Novak esc
Yes sir...Is there a way to adjust out the surge when you turn it on and off ????
Re: Novak esc
The old ones did that. It's just nature if the beast
- integra22t
Re: Novak esc
im use to the surge .. i like it as i know the car is on .. strange the plot is off that far maybe you should have driled the case so you can
Re: Novak esc
I thought about that but it is in very good condition other then that and with my luck I would screw something up...So I will leave it alone and just be glad that it does work lol...
Re: Novak esc
Radio is a KO PROPO EX5..
Re: Novak esc
We are both stuck in the age of AM TX If it ain't broke, don't fix it.
FYI Futaba JR low and high throttle ATV pots should be set to 10 (max) before dialing in Novak speed controls. Use the throttle trim for neutral/brakes.
Re: Novak esc
I like the old stuff and all of mine still work...Thanks for the info...
- 1737 Views
Last post by teman
- 1405 Views
- 22 Replies
- 3712 Views
Last post by Dangeruss
- 1719 Views
Last post by Asso_man!
- 3865 Views
Last post by Tadracket
- 680 Views
Last post by GJW
- 909 Views
- 628 Views
Last post by AndrewSi
