what is this connector?
- Lonestar
- Has thanked: 626 times
- Been thanked: 167 times
Hey Guys,
can anyone point me to the proper name for such a connector? Thank you
Paul
Paul
- Been thanked: 292 times
Re: what is this connector?
Looks like a motherboard P4 connector (4 pins). Depending on the motherboard, they sometimes snap together to fit into an 8-pin socket, but usually just one plugs into a 4-pin socket--the one with the differently-shaped white plug-ends, not the one with all the ends shaped the same.
I can't quite see in your image, but if they're 6-pin connectors, they're auxiliary power connectors for high-end video cards.
Actually Dennis, the 4-pin ATX extra connector isn't yellow/black, and can be optionally connected to the large ATX motherboard connector.
I should clarify that the 6-pin video card connectors are PCI-Express auxiliary power connectors.
- Lonestar
thank you gentlemen!
- 1432 Views
Last post by TRX-1-3
- 1109 Views
Last post by JosephS
- 1106 Views
Last post by kaiser
- 695 Views
Last post by b027
- 661 Views
- 1403 Views
Last post by b027
- 196 Views
- 1546 Views
