Jeek's Specs Super Astute Build
- jeekelemental
- Has thanked: 39 times
- Been thanked: 12 times
From several weeks I'm restoring a Super Astute bought after Christmas 2014. The car was in awful condition (previous owner said it was perfect): missed screws, rusted turnbuckles, cracked plastics and generally dirt and neglected.
For first I've disassembled the car and divided all the parts candidates to be saved from the other to be discarded.
I made a huge inventory of the new parts needed and I'm buying it in several steps to avoid the bankrupt.
The build of this car isn't, from its start, a true restore; it wants to be a kind of upgrading made on my own specifics.
Many parts are 3d printed and I'm using stainless steel screws all around.
New housing, polished motor plate, full ball raced, gears deeply cleaned.
The TTC sits in place, Corally 16x2 brushed motor refurbished by me
Handmade battery stops, it needs to be finished and polished but I'm happy.
"Flagellum Dei"
Powered by Flux Capacitor
Re: Jeek's Specs Super Astute Build
Nice build and looking great so far! Like the homemade battery tray!
Super Astute was my first 2wd off road buggy so got a soft spot for it!
- Has thanked: 14 times
- Been thanked: 14 times
Wow! did u print that front bulkhead! it looks great with the incorporated bracing! nice job
looks like u did the steering belcranks too, they look nice and beefy, the standard ones were a bit too fragile
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
Yes, great work with the custom parts. I can't wait to see how it turns out!
- jeekelemental
All the 3D prints come from ORB Racing in the Netherlands.Delorean wrote:Wow! did u print that front bulkhead! it looks great with the incorporated bracing! nice job
Bulkhead and brace are two separated pieces... I've asked them for a single piece but they need time.
I'm going to send them Mad Cap arms to obtain a 3D printed copy gain stiffness (I don't own SA arms but MC ones are slim and I prefer how them look).
"Flagellum Dei"
- jeekelemental
Yesterday I made some tests with a standard servo and I have to say that there isn't much room. Some stuff are coming and I will try to clean a little the chassis around the battery. Not many ideas and confusedRichieRich wrote:Yes, great work with the custom parts. I can't wait to see how it turns out!
"Flagellum Dei"
in my astute i ran a low profile servo and put the battery holder as far forward as it would go so i could move the battery forward and back to adjust the weight balance
even if the bulkhead and brace are 2 pieces, they look great!!
- jeekelemental
Turnbuckles and more in place. Using Tamiya IFS suspension's rocker as inner pivots I tried to limit the MadCap arm's twist problem (awaiting for 3D printed ones). Turnbuckes are completed with 5mm ends outer and with 6mm ends inner so I will be ready to swap to uniballs if necessary.
"Flagellum Dei"
- jeekelemental
Battery holder almost complete. I took inspiration from the modern Lipo holder, I will build a battery strap ASAP. Some Urethane cuts will help the battery to sits in place.
"Flagellum Dei"
- jeekelemental
Full MadCap setup for the back, arms needed minor modifications. Some doubts about unis integrity
"Flagellum Dei"
- jeekelemental
Complete, thanks for watching.
"Flagellum Dei"
- jeekelemental
Thankslmwong wrote:Wow, I really like how this turned out? How does it run?
I drove it for a pair of times on tarmac because of old and tired wheels: it's fantastic, precise and stable, well balanced... it needs only some set up adjustment (springs). Received 2 or 3 days ago Schumacher tires for grass and it's all ready for next holidays.
"Flagellum Dei"
- Been thanked: 11 times
I like the build - you've put a modern twist to it. I have a super astute that I'm going to do in Box style.
The shell is nice...what was the inspiration for the decals?
- jeekelemental
Many thanks! The body work is made more by a need than by an inspiration ... I'm not a great painter so I called in my help some stickers and in particular the Tamiya style skulls made by B-side Label in Japan.
"Flagellum Dei"
- 24 Replies
- 3768 Views
Last post by shodog
- 1016 Views
Last post by Jirka
- 36 Replies
- 5088 Views
Last post by RCveteran
- 2873 Views
Last post by TheDiamondOne
- 1310 Views
Last post by XLR8
- 37 Replies
- 6733 Views
Last post by isaidme
- 2365 Views
Last post by Jirka
- 26 Replies
- 4040 Views
Last post by BillKrueger
Users browsing this forum: Facebook [Bot], Tbot [Bot] and 5 guests
