RC10DS - Martini Porsche 911
- LoboNYC
- Has thanked: 814 times
- Been thanked: 344 times
A while back i purchased a Tamiya Martini Porsche 911 body kit and put it away for a future build. I decided to finally start the build a few days before Christmas. The donor parts came from a crashed carbon chassis mustang DS car i had laying around.
I started with a "B" stamped Emerald Green anodized chassis, nose plate and nose tubes. I scored this anodized beauty on ebay from Don Martin a while back and had been saving it for a future build.
Blue GPM suspension arms & Carbon Fiber Shock Tower
Front Stabilizer
NTC3 Rear 12mm Hexes
Front end suspension attached to nose plate
Nose plate attached to the chassis
The rear
MIP CVD's will be used
The intended wheels were the HPI Porsche set but they proved to small for this project. They were made for a different line. I ended up getting a set by Tamiya in red. On both sets i painted the inner wheel black
See the difference?
oh but they looked so good...
but they were too small
The Tamiya body is mounted, prepped and ready for paint....
Tight Lines...thats how i roll
Decals On...
Of course i managed to place the eight upside down ....it was too late to remove
Front end bumper and mounts. Body mount were positioned different than stock to accomadate the body
Powered by Castle Creations Sidewainder 3 brushless non sensored setup. 4 pole
The front end is a joy to look at..reminds me of a dragon fly
transmission end cups polished
The Rear is end is solid and mean
Side View mirrors on...
My RC10DS Porsche Carrera Martini
Front Stabilizer
The rear
See the difference?
Decals On...
- Diamond Dave
- Has thanked: 567 times
- Been thanked: 103 times
- LoboNYC
Re: RC10DS - Martini Porsche 911
Those are Tamiya wheels and tires. They are 12mm hex sized so they fit the DS. I enlarged the center hole so that it clears the axle and sits perfectly on the hex.
I used the front hub and axle assembly from the associated sc10 in order to use regular 12mm hex wheels. You'll have to enlarge the hinge pin hole in order to mount onto the DS. You can mount HPI, Tamiya, RC4WD or any other 12mm hex wheel you prefer. You may have to enlarge the center hole on some of the wheels though.
Diamond Dave wrote: ↑Sun Jan 22, 2017 12:49 am Such an awesome look! No idea for an answer for ya. Awesome look!
Thanks Diamond Dave! The SC10 Front axle and hub assembly is what i mounted onto the DS.
Thanks! And you are so right. I was contemplating using the body on a nitro DS but the electric is more suited for the 911 body being that both have the engine in the rear.
- LoboNYC
thanks Erik, I can finally say I'm done and now I can start thinking of the next DS
- Diamond Dave
Very great look, I want one.
Detail is everything, going to run it? It should run as good as it looks...
- CruzinCustomz
- Been thanked: 10 times
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Awesome rear-motor 911
- LoboNYC
Thanks DiamondDave! and to answer your question, yes im going to run it and I'm definitely looking forward to it. Im curious to see how the setup performs.Diamond Dave wrote: ↑Tue Jan 24, 2017 3:17 am Very great look, I want one.
Thanks! it took much trial an error with various wheel offsets and hex sizes to get it right. Wheelbase was a major issue in trying to mate the Tamiya body to the Associated chassis. The front wheelwell had to be enlarged in order for the wheel to clear the body.
Thanks Lonestar. Having that rear engine will definitely make it feel like a 911. Swinging that rear around is going to be lots of fun
Absolutely awesome! PLEASE PLEASE link to those wheels and tires. Please!
-Mike
RC10T | Kyosho Lazer ZX - 55mph | Mid Motor RC10 Pan Car Conversion - 72mph | OIN RC10 spare/used parts build - 69mph | 4x4 MonsterT build
86 ascMcLaren Capri 5.0 | 86 Mustang SVO
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- klavy69
- Moderator
- Has thanked: 556 times
- Been thanked: 262 times
I'm guessing by the info above in the post its these wheels TAMIYA RC COMPLETE WHEEL SET "PORSCHE RSR FOX RIMS" 1:10 1in / 1 5/16in WIDE
- LoboNYC
Those are Tamiya wheels and tires. from their porsche rsr kit. I got them from ebay. klavy69 (thanks Todd!) posted a link.
klavy69 wrote: ↑Wed Jan 25, 2017 10:14 pm
- 1320 Views
- 1774 Views
Last post by Mr. ED
- 26 Replies
- 5370 Views
Last post by shodog
- 22 Replies
- 4309 Views
Last post by tamiyadan
- 29 Replies
- 4349 Views
Last post by LoboNYC
- 653 Views
Last post by cobalta70
- 1336 Views
Last post by civilguy
- 26 Replies
- 4521 Views
Last post by jeroen206
