Trinity motor, please help....
- MarkyDents
- Has thanked: 1364 times
- Been thanked: 512 times
I’m trying to find out what this motor is, and what era (years) its from. Mainly trying to figure out what turns and winds it could be as well. Please help !
Hey Cru ! Go balls out
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: Trinity motor, please help....
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.dirt-burners.com/rcdox/Catalogs/Trinity/1992-93%2520-%2520The%2520Trinity%2520Racers%2520Catalog%2520%2528winter%2529.pdf&ved=2ahUKEwjoh_nJ2Z_wAhXKKM0KHRGRAH4QFjACegQIBxAC&usg=AOvVaw0OhNdfW9f7mp1PErtXmYtS
They were available in multiple winds. Probably best to check the armature for markings.
- MarkyDents
Thank you very much ! That catalog sure does make it sound like a nice motor to have. I really appreciate you finding it.
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 132 times
Thank you, too, for that Trinity catalog link. I have one of these motors as well, and I've always wondered what it was. It really would have been nice if more motors had permanent identifiable markings.
Matt
- Lowgear
- Has thanked: 78 times
- Been thanked: 601 times
That's been a major hurdle I've found while going down the rabbit hole of brushed motors as it pertains to identification. Manufactures used the same cans and decals as a time and cost cutting measure I imagine which makes it hard to know what's what. I've also regularly come across the same part numbers being used, or even no part numbers at all. Like for example a company would use one part number, and then write on the header card of the packaging the turns and winds. So for a lot of these motors the only way to know what the specs are is to take them apart to examine the armature.
- Regular Member
- Has thanked: 14 times
- Been thanked: 13 times
Very, very true for mod motors for sure. Stocks have the tabs that make thing a bit simpler. Cheap or expensive mod is easy to tell based on how nice the wires are wound and if they drill or epoxy balanced. After that, good luck. I have had some luck weighting the the arms. Lighter arms being lower turns/winds than then the heavy ones. But that's not 100% right, just a best guess type thing.Lowgear wrote: ↑Wed Apr 28, 2021 4:18 pm That's been a major hurdle I've found while going down the rabbit hole of brushed motors as it pertains to identification. Manufactures used the same cans and decals as a time and cost cutting measure I imagine which makes it hard to know what's what. I've also regularly come across the same part numbers being used, or even no part numbers at all. Like for example a company would use one part number, and then write on the header card of the packaging the turns and winds. So for a lot of these motors the only way to know what the specs are is to take them apart to examine the armature.
(I should have read the whole post. )
You may know me as Jessica. Or, that girl that raced a Stampede at SoCal Raceway. Maybe, that girl with the big big block El Camino.
IG and YT @ Jessica's 2 Car Garage https://www.youtube.com/channel/UCMP9VnJ76BZv6EZJSRke_pw/
- 55 Views
Last post by Dangeruss
- 2805 Views
Last post by jamin
- 95 Views
- 1099 Views
Last post by SteveMax
- 143 Views
Last post by R6cowboy
- 2033 Views
- 34 Views
- 701 Views
Last post by nvxwax
