Kyoshso Beetle re-re
- Has thanked: 1025 times
- Been thanked: 485 times
Where does the Beetle fall in the Scorpion-Tomahawk-Beetle spectrum? It wasn't on my radar at all, but a NIB re-re popped up for sale locally for a fair price.
Is it literally a Scorpion with a Beetle body? Were there changes and performance differences between the cars in that series? I know the Turbo Scorpion was superior to the rest of the line, but I am not familiar with the Beetle. Thanks in advance for any info.
If I get it, it will be a runner. My home track is pretty bumpy, so well suited to a trailing arm setup.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1745 times
Re: Kyoshso Beetle re-re
Mechanically? Yes.
There are some cosmetic changes. Wheel design, plastic colors, etc.
As for the Turbo Scorpion, I don't think that there are many mechanical differences between them. At least, as far as the basics go. The 2.2 wheels are clearly different, as are the rear hexes. After that, I think it's mostly cosmetic.
- RogueIV
- Has thanked: 1113 times
- Been thanked: 455 times
Turbo Scorpion has a wider front track and longer wheelbase as well IIRC.juicedcoupe wrote: ↑Tue Dec 26, 2023 11:45 amMechanically? Yes.
- juicedcoupe
Because of all the aluminum parts, I've been hesitant to run mine very much. It looks like it could easily be bent in a wreck.
Getting tangled up with something heavier (like a Bandit) might even mangle it.
From what I have found on the interweb, the Scorpion and Beetle are largely the same. The Tomahawk has better shocks (from the re-re Ultima/Optima) and a different steering servo location. The re-re chassis rails are much stronger than the original parts (now made of 6061 aluminum).
From this, it appears that there are no "good" or "bad" choices; it is really down to preference with the body.
- juicedcoupe
I went with the Beetle but I would have liked to have also gotten a Turbo Scorpion when they were available.
- RogueIV
My local hobbyshop has one in stock if you're still looking. R/C Madness in Enfield CT. I think they ship.juicedcoupe wrote: ↑Tue Dec 26, 2023 5:26 pmI went with the Beetle but I would have liked to have also gotten a Turbo Scorpion when they were available.
- silvertriple
- Has thanked: 593 times
- Been thanked: 860 times
And you forget the longer shocks which is the last technical difference. Another one is the wheel drivers friction based on Tomahawk, Scorpion and Beetle, and hex on the Turbo Scorpion...RogueIV wrote: ↑Tue Dec 26, 2023 12:28 pmTurbo Scorpion has a wider front track and longer wheelbase as well IIRC.juicedcoupe wrote: ↑Tue Dec 26, 2023 11:45 amMechanically? Yes.
- 24 Replies
- 3245 Views
Last post by GreenBar0n
- 1139 Views
Last post by cooltoys
- 1122 Views
Last post by Diggley
- 583 Views
Last post by breck
- 1229 Views
Last post by juicedcoupe
- 28 Replies
- 5435 Views
Last post by alien3t
- 696 Views
Last post by Medved
- 1329 Views
Last post by XLR8
