lolRedScampi wrote:HotRodJosh wrote:
I prefer to call the color, "Deep Purple".
Another buggy for me! :)
Re: Another buggy for me! :)
RAWPWR
What kind of dye did you use? I did all my white parts royal blue but they came out purple. Now I'm trying to die them black but it's not going very well. I'm using fabric dye which I used before.
I used RIT fabric dye. It always works very well for me. Step by step, what are you doing and what issues are you having?FordPSD wrote:What kind of dye did you use? I did all my white parts royal blue but they came out purple. Now I'm trying to die them black but it's not going very well. I'm using fabric dye which I used before.
Gary
I used hot tap water and let the parts sit over night. I'm thinking of boiling the dye on our outside grill and then soaking the parts. It turns out the dye that I am using is Rit Liquid fabric dye. The parts have been soaking for about 16 hours now.
That would probably be the issue. I boil the water with a bit of salt, drop it to a simmer then add the parts. Stir it a bit now and then. It should only take 15 to 30 minutes max. I use an old sauce pan on the stovetop and a cheap spaghetti strainer to pour the parts into afterwards.
Gary
RedScampi thanks. I'll boil the dye on the gas grill and try that and add some salt. I'm not allowed in the ktchen ever since I used my wifes oven to bake paint on auto parts.
You're welcome! I have thought about baking parts in our oven but it's new and I'd probably be crucified! I can get away with the dye thing in the kitchen because I'm very careful and clean up after myself. It also doesn't hurt that we have black appliances and counter tops.
Gary
Scampi that was it! Heat and lots of it. I got the grill up to 350 degrees which got the dye steaming. I left the parts in there and just stirred them. No luck at first. In fact at first it was discouraging because it looked like the purple was coming off a little and no black was adhering or penetrating. But once the heat got up there and lots of salt was added you could see it changing. I could not get the dye to boil but I did open the lid frequently when the temperature got above 350. My grill can usually get to 600 which means I probably have a rotted out burner.
I then got a spackle bucket that my wife uses for weeding and filled it with cold water outside and set it on the grill to put the parts in. Fearing I might miss some small parts I just poured the pan of dye into the bucket. It was then I realized the bucket had a hole and was getting black dyed water all over the patio and pavers! This is all taking place in 35 degree weather!
Well after the mess and all got done the parts are drying behind me! Thanks.
Cool, glad that worked out for you! You could dye your entire patio black.
Gary
- 86 Views
Last post by TycoTamiya4eva
- 22 Replies
- 2874 Views
Last post by Frankentruck
- 793 Views
Last post by klavy69
- 1270 Views
Last post by fastang
- 1348 Views
Last post by mikea96
- 1647 Views
Last post by joel45acp
- 3051 Views
Last post by THUNDERSTRIKE1
- 45 Replies
- 4265 Views
Last post by romulus22
Users browsing this forum: Ahrefs [Bot], Facebook [Bot] and 2 guests
