Slipper clutch questions
Ive done some searching And cannot find a for sure answer on what newer slipper clutch and top shaft will fit the stealth tranny. I have the one with the pin that the spur gets screwed in. i hate these screws and dont want them any more. So to update it. I know i need the flat shaft one. What car is that out of? B4, B44, Rc10t4.1????? I only ever here very short reference to what it is. I dont want to waste money on the wrong one.
Re: Slipper clutch questions
do i have to swap top shaft to the flat style or keep my round pin type?popboy905 wrote:the b4-b4.2 slipper works with the stealth or you can get the slipper from the stealth re-re
- bully
- Been thanked: 6 times
All info here mate, get a B4 top shaft spacer in case
http://www.rc10talk.com/viewtopic.php?f=38&t=29690
thankyou very much excactly what i needed.bully wrote:All info here mate, get a B4 top shaft spacer in case
- Regular Member
I have a b4 flat side top shaft in my a gold buggy stealth conv, pros two sided slipper, spur change WO changing slip peer setting, ease of finding spurs. Con b4 dust over only lines w one bolt hole, top shaft too long to fit inside original. I cut the access plug and run w a piece of masking tape till I find a better way?
sounds good. i have a grinder i could just grind it to the right lenght.yellabelly wrote:I have a b4 flat side top shaft in my a gold buggy stealth conv, pros two sided slipper, spur change WO changing slip peer setting, ease of finding spurs. Con b4 dust over only lines w one bolt hole, top shaft too long to fit inside original. I cut the access plug and run w a piece of masking tape till I find a better way?
oh...I have the original stealth case i dont see the top plus people are talking about. Did they make 2 versions?
- Regular Member
may then have to then use shorter spring, I opted to use shaft as is. its possible that the longer spring may function better, smoother? did u mean plug? if so its on the side of dust cover. allows slipper adj wo dust cover removal
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEDYZ&P=Z
or if you use the b4 cover, you will need to punch a new hole into your plate. just as we did before, before the worlds car came up.
― Confucius
― Confucius
- RC104ever
New style VTS slipper also works once you've done the B4 topshaft conversion
- Chris
Lots of cars...so many cars
- DMAT
There is a thread in the tech section for this conversion.
I've converted all my stealths to the B4 or VTS slipper aside from my 6-gears. also did this to a rustler vxl
the asc7486 slipper spring works on both B4 and VTS slippers.
- Regular Member
- 3975 Views
Last post by Dirtcar75
- 24 Replies
- 2783 Views
Last post by fredswain
- 813 Views
Last post by Group B
- 717 Views
Last post by vintage88
- 1425 Views
- 945 Views
Last post by rustler85
- 2292 Views
- 1064 Views
Last post by slow_jun
Users browsing this forum: last5liter and 20 guests
