What do you think?
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Re: What do you think?
Post by XLR8 »
The new MB's probably have proper dog bones rather than those funky hex bones. I think Tamiya finally retired those hex drive axles long ago.
Anyway, I'm pretty sure the new Blackfoot and Brat versions have dog bones so it seem reasonable the MB would have them also.
That said, the stock gear diffs are said to be total crap so it's probably wise to upgrade to MIP.
EDIT: I just had a quick look at the manuals and Frog and Brat use dog bones while BF and MB use CVA's. So it appears to depend upon tire size but all of them still use that awful gear diff.
Typical Tamiya: don't correct ALL the known problems with the vehicle, let the customer do that. :roll:
Sprocket
Has thanked: 6 times
Been thanked: 9 times
Post by Sprocket »
If you didn’t want to spend the money on a MIP diff, there are relatively inexpensive braces that work
XLR8
Post by XLR8 »
Sprocket wrote: Tue Dec 07, 2021 1:35 am If you didn’t want to spend the money on a MIP diff, there are relatively inexpensive braces that work
Link please? :D
cdnclodbuster
Post by cdnclodbuster »
I don't mind spending the cash on it but if there is alternatives sure would look at it. :) But if alternatives (bracing) is used will the gears inside still give problems ?
cdnclodbuster
Ya just ordered the MIP ball diff, dang a month to wait for that part wow is that the same everywhere ? :shock:
Sprocket
Post by Sprocket »
https://www.tamiyaclub.com/forum/index.php?/topic/94042-monster-beetle-frog-gearbox-fix-a-new-strengthener/&
Talk to a guy that goes by Xeostar. Really nice guy. That thread will answer a lot of questions
If he does not have any made up right now, check eBay(esp UK version) as they pop up occasionally.
Hope this helps
cdnclodbuster
Thanks I will do that.
cdnclodbuster
Also just a side issue that is MB related. I noticed today while I was driving the beetle that it steers better right than left (tighter turn ) I have the steering trim set so it will drive straight. Do I need to take the servo saver off and move it a notch in the opposite direction then reset the steering trim and adjust accordingly. Sorry for probably a stupid question still kinda new to RC. Thanks :mrgreen:
Has thanked: 269 times
Been thanked: 2095 times
Make sure that the servo is properly centered, fairly close to where the you drive straight.
To complicate this, cars with offset steering linkages tend to not steer the same in both directions.
Better transmitters have adjustments that can somewhat tweak this.
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
That’s what it sounds like.. Take servo saver off, turn on radio system & set the trim back in the center, reinstall saver.
-Brad
BattleTrak
A common modification is to center mount the steering servo and use equal length tie rods.
-Brad
cdnclodbuster
I take it that even length rods are aftermarket.
cdnclodbuster
Ya thanks battletank thats what I was thinking cause the steering trim is maxed out .
Users browsing this forum: No User AvatarGoogle [Bot], No User AvatarGoogle Feedfetcher and 13 guests
