my only off road is my back yard. (and it is tiny)
unfortunately I do not have another 27T motor to try. My only other motors are an 8T and a couple others I am not sure what they are (they are almost as old as the buggy)
jwscab wrote:I haven't really run it yet, but from the specs it looks pretty reasonable.
I picked this up the last tower order, I have no reason to think it won't work well.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUJ0&P=7
they have a selection from 13 to 21 turns (odd number).
as far as gearing, I haven't looked at them in awhile, but from what i remember, I used to run high 80's spur, pinions on the order of 17-20 all 48 pitch. undergear and creep up on a good combo, rather than start high and ruin things.
bear in mind that if you are running for more than 5 minutes or so, they will start to run hot.
Well, I had the Venom mod 19t on the Yoke for all of 2 weeks. When I switched to LiPo, the thing screamed and fried. Got so hot it melted the cover a little. I ran it for 10 minutes, and it was fast. Won't even turn now. So I put the brushless in it. Love it.....campbuds wrote:I have heard venoms stuff is junk
I bought a cheapie LRP system at a lhs. Sensored system, but it didn't have the sensor wire with the kit. Bought the sensor wire at tower for $7.95, and still spent less than $150 for the setup. I like it just fine. LRP 13.5T Eraser with reverse/LiPo cut off esc.jwscab wrote:well...the lipos have a higher working voltage, and can sustain that for alot longer than the nicads ever did. I would say running it at part throttle under high load would pretty much smoke any brushed motor for longer than 5-8 minutes.
i know the feeling though, alot of these brushless systems are pretty pricey. I've been kicking around picking a system, I was thinking LRP or Novak for ~150.00-ish.
there is also the option of trying out the cheapy stuff from overseas, we had some decent luck flying foamie airplanes and helis with that brushless stuff.
Users browsing this forum: No registered users and 30 guests
