Stealth trans to grease or not to grease, if so what kind?
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Stealth trans to grease or not to grease, if so what kin
Post by klavy69 »
Charlie don't surf wrote: Areo lube? Was that the teflon stuff that once the liquid carrier evaporated it was supposed to leave a silky coating on the parts?
Yep, thats the stuff I have anyway. Used to use it on slot cars too.
300D50
Post by 300D50 »
I hate to see what the bearings look like after a toothpaste treatment!
Then again, they would be "minty fresh". :lol:
Walt
Some people never have anything except ideas. Go do it.
Eau Rouge
Post by Eau Rouge »
IIRC, the toothpaste treatment back in the day was to break in the original bronze Oilite bushings, and not the gears. The gears in the 6-gear that needed break-in help were the steel idlers and top shaft. Under a magnification loupe, you could see rough edges and tiny burrs. Toothpaste isn't going to fix that—just make a big mess.
gjeeper04
Post by gjeeper04 »
I think toothpaste would fix it, as long as it has some abrasive qualities.
Eau Rouge
Post by Eau Rouge »
Toothpaste is not abrasive enough to remove metal, otherwise it would remove tooth enamel, too.
Has thanked: 356 times
Been thanked: 470 times
It will remove enamel, if you ran it at 29k rpm! :lol: its more abrasive than you think, one of the tricks to restoring old ( pre 77 ) Rolex watch lenses is AIM toothpaste and a soft cloth-
Eau Rouge
Post by Eau Rouge »
Charlie don't surf wrote:It will remove enamel, if you ran it at 29k rpm! :lol: its more abrasive than you think, one of the tricks to restoring old ( pre 77 ) Rolex watch lenses is AIM toothpaste and a soft cloth-
Oh I know... I have used it with great success on sunglasses and watch faces. But the kind of burrs on original 6-gears you'd have to run it at 29k RPM for days to remove enough material. Jeweler's files, a Dremel, metal polish and lots of time will clean up the gearbox teeth, not some magic break-in bullet. Trust me, I've tried everything over the last 27 years.
valve grinding compound. worked wonders for the gear diff in one of my sp-1's. :mrgreen:
gjeeper04
Post by gjeeper04 »
Valve grinding compound that is an awesome idea.
I never thought about it with 32p gears!! I was raised in the stealth era!! :lol:
gjeeper04
Post by gjeeper04 »
I was more worried about the stealth when I posted this but all good info.
Users browsing this forum: No User AvatarBing [Bot] and 3 guests
