2014 Vonats Team Losi XX4 WE Setup
R/Cat
Re: 2014 Vonats Team Losi XX4 WE Setup
Post by R/Cat »
pumpkinfish wrote:I raced a WE chassis with the lowered mount at the VONATS and my car was fine. I didn't notice any extra dust/dirt inside the car. If you were going to run outside on a blown out track, then I would suggest the chassis protector to seal it off.
I also used a 4-40 tap on my car. I never thought to use the set screw trick though. I may have to implement this trick.
Mark, I see you are using the middle camber hole on the front tower. I used the inside hole. Any reason you went with a shorter link?
Good to know. Do you know if there is a chassis protector specifically for the xx-4 or do you have to use an Associated protector from another model? Also, my research indicates that the xx-4 was released 1997. If so, why is it allowed to run in the pre-1994 VONATS?
Beau S
Post by Beau S »
They only 4wd Buggys before the xx4, raced competitively, were mostly Yoks & Shueys.
I've noticed how truly rare those parts are. The xx4 still has a ton of parts available, so I think that may have been the reason for the exception.
Plus, the xx4 was a game changer for the 4wd class, in the US, and has a solid cult following.
Return to “Losi Forum”
