Some tuning options for racers and runners
General info, Q&A.
alien3t
Re: Some tuning options for racers and runners
Post by alien3t »
mk-Zero wrote:I can do the spacers, no problem.
Unfortunately i dont have a stealth cap on hand to measure. If you want to send me one I'd be happy to measure it, then i could give you a free one from Shapeways (and send you yours back) for the trouble.
we can do that, I have a cap on one of the ones here, I can bring it buy 1 day this week. since you are in orange.
http://www.ebay.com/itm/VINTAGE-TEAM-ASSOCIATED-STEALTH-TRANSMISSION-MOTOR-PLATE-SPACERS-END-CAP-6569-/221657377668?pt=Radio_Control_Parts_Accessories&hash=item339bcf2b84
kit trying to replicate
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Post by mk-Zero »
Oh cool, that will work. I cant imagine those spacers and cap from shapeways would even be 10 bux.
alien3t
Post by alien3t »
exactly. lol and not a high stress structural parts like arms. have gotten 2 used cases, both missing spacers. 1 missing cap
mk-Zero
Business Member
Post by mk-Zero »
Cool, should be a great use of this technology.
I'm going to update the first post of this thread with a running list of things I'm going to design and make on Shapeways.
harvey
Post by harvey »
You guys rock with your high-tech custom parts ordered from the Cyberspaces! I hope you get a kick back when we order your designs from shapeways?
Anyhow, I have a suggestion for the castor wedges, and that would be to build them into the front arm mounts. I know this is way more work but wait: if they were one piece the screw hole could be square with the bottom of the mount, which would make the screw head sit flush in the bottom of the chassis. I know those oval guys aren't landing jumps (on purpose) but surely flat screws would be a boon? This would make them a lot better than the originals IMO.
mk-Zero
Business Member
Post by mk-Zero »
That's how my arm mounts are in the first post, the screws are perpendicular to the bottom surface so the screw heads sit flat, but the hinge pin holes and shock tower mounting surfaces are tilted. What kind of angle do they need to be for the oval guys?
harvey
Post by harvey »
I can't say since I'm strictly off road, but a long search turned up reference to 10 degree cheetah castor wedges. Sounds likely, since I don't think you'd use a lot of castor on-road. Guys could use your new -5deg blocks (25 degree) to get 5 degrees of castor if 10 degrees was too much when using 30 degree blocks.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
The Cheetah ones were 5 or 10 degree IIRC. I always ran Ascot sprinters, not BBT, so I didnt need the wedges :)
fredswain
Post by fredswain »
I have several of those wedges in a bag of parts. I'll try to remember to dig them out tonight to measure them.
mk-Zero
Business Member
Post by mk-Zero »
fredswain wrote:I have several of those wedges in a bag of parts. I'll try to remember to dig them out tonight to measure them.
Cool, thanks Fred 8)
mk-Zero
Business Member
Post by mk-Zero »
Here's the CAD model of the Stealth spacers, I'll add the Stealth cap to it once I borrow the part from alien3t 8)
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Hi mk-zero,
Nice work!
I also have a BBT sprint car so I also will be interested in caster wedges.
Thank you, DaveM.
mk-Zero
Business Member
Post by mk-Zero »
Good to hear there's interest. As soon as i get an angle I'll design them and have some made.
fredswain
Post by fredswain »
Just measured them. They are 10°.
mk-Zero
Business Member
Post by mk-Zero »
fredswain wrote:Just measured them. They are 10°.
Awesome, thank you Fred, I appreciate that. 8)
