OPEN losi xx4 discussion
geeforce59
Re: OPEN losi xx4 discussion
Post by geeforce59 »
Gosh! these scene looks familiar with my XX4 :shock:
rccars4sal
Post by rccars4sal »
So, whats the best way to prevent this? Keep the belt covers well sealed? What about diff grease, does it eat the belts? Get the tough belts?
knixdad
Post by knixdad »
They all seem to fall apart for any number of reasons.
I'm hoping the new belts for the 22-4 are better somehow.
slapshot1979
Post by slapshot1979 »
I would blame the front one on dry rot of sorts as you can pull on belt and rebreak it no problem. the other 2 would be dirt buildup on pulleys and running little roller thingys. Last one would be again dirt and a slight thrashing by the guy behind controller :roll:
integra22t
Post by integra22t »
or the 6 feet of air :lol:
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
I raced a XX4 for quite a while, as long as my diffs and slipper were good, I never roasted a belt.
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
I did ask while at the iHobby show, and it sounds like the belts for the 22-4 are not the same length.
About the only parts that looked like there might be even a chance to work on the xx4 are the black rubber access cover and and perhaps the battery straps.
knixdad
Post by knixdad »
mytimac wrote:I did ask while at the iHobby show, and it sounds like the belts for the 22-4 are not the same length.
Too bad about the belts, but there is always a chance that something minor might be able to be changed to make it work. I just pulled apart a Street Weapon that had a XXT steel diff in it, with the Weapon rear gear. Maybe swapping some gears around might work.
Or not, either way, I'll see what I can do once the kit is out.
jamin
Been thanked: 28 times
Post by jamin »
mytimac wrote:About the only parts that looked like there might be even a chance to work on the xx4 are the black rubber access cover and and perhaps the battery straps.
I've ordered some of the plugs to replace the horrible yellow ones I have on my SW and XX4 :lol: 8)
slapshot1979
let us know if they fit as I need some too.
slapshot1979
anyone running frt/rear sway bars? I have a NIP set that I may install during this winters rebuild
rccars4sal
I just scored a baggy of xx4 parts! aluminum CVDs, steel CVDs, drive cups,, and...... trinity drive cup steel strengtheners!!! bunch more junk too.
slapshot1979
Well I spent a good 4 hours wrenching time on my xx4 tonight, I love working on this thing. not really doing anything just tweaking.
Is there any news about the 22-4 parts fitting the xx4?
I installed rear sway and was wondering if anyone is running a front one.
zuki250
Post by zuki250 »
I own both...and everything in the 22-4, while it looks similar, is not gonna work.
Martym10
Post by Martym10 »
Still racing XX-4 even in 2019 :D
5th overall :!:
Return to “Losi Forum”
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot] and 4 guests
