Luke's Procat rebuild
kaszal
Post by kaszal »
Thank you for your kind words, Jason :D
I've learned so much that I can apply to my new Kyosho FS2... but that won't be ready for at least a month. Until then I'm going to keep racing the Procat like it was intended 8)
I see you're selling your spares... are you weaning yourself off the vintage Cats? It's very difficult saying goodbye to precious vintage spares :cry:
Bormac
Has thanked: 20 times
Been thanked: 11 times
Re: Luke's Procat rebuild
Post by Bormac »
You're welcome Luke.
I've been buying up cars and parts for these cars for years. I have finaly finished all my Schuey builds so I figured why not turn out whats left over. :wink: :mrgreen:
-Jason.
Still known as- bormac
kaszal
Post by kaszal »
Good stuff... so are they retired or still raced in anger from time to time?
I think I have enough spares to assemble a complete front diff like the one in my Procat... dare I sell it? I've got a brand new overdrive pulley, alloy super hex diff washer carriers, B-Fast flattened Losi plates, carbon fibre pulley fences and I think some 3mm ceramic balls. I'll have a look tonight so heads up everyone :wink:
Something I don't have for my Procat is the alloy H-bracket that goes between the chassis decks... or this beauty...
kaszal
Rare diff parts for sale...
Post by kaszal »
Almost a complete front diff conversion, the same as I have in my Procat.
Ends on Sunday...
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=270988980422&ssPageName=ADME:L:LCA:GB:1123#ht_3963wt_1139
kaszal
Once they're gone they're gone!
Post by kaszal »
By the way, those diff parts cost well over £40 and some time and effort to collect. I don't have any more spares of those parts so do check them out...
http://www.ebay.co.uk/itm/Schumacher-Procat-diff-conversion-/270988980422?pt=UK_ToysGames_RadioControlled_JN&hash=item3f1833b0c6#ht_3979wt_1139
Jason also has some vintage goodies for sale...
Search for eBay item 180896856147
kaszal
Schumacher super hex diff v. MMS diff
Post by kaszal »
Hello, I had a question about the front diff I'm selling and how it compares with the MMS diff...
- The Schumacher diff has machined alloy washer carriers (more precise, stronger and heat absorbing) whereas the MMS diff has nylon (plastic) carriers.
- The Schumacher diff has twin ball bearings housed in the alloy halves instead of the single centre bearing in the MMS diff.
- The Schumacher diff can take a belt up to 6mm wide if you want to do my modification. On the MMS diff the pulley guides get in the way. I have a spare 6mm neoprene belt if you want it.
http://www.oople.com/forums/showpost.php?p=576953&postcount=312
- It is supplied with an 'overdrive' pulley, which gives more 'pull' round the corners. Again, this is what I use in my Procat racer.
- The pulley fences, if you wish to use them, need to be superglued onto the pulley. I carefully sanded both before gluing and they've stayed strong so far...
http://www.youtube.com/watch?v=PZIkSMEYosQ
Let me know if you have any questions.
kaszal
vintage Schumacher spares
Post by kaszal »
In case you haven't seen them yet, these auctions are ending this weekend...
kaszal
saddle trays
Post by kaszal »
I'm swapping to saddle packs for my Kyosho Lazer FS so I drew some new trays and straps for the Procat.
They can be used wit the existing posts so hopefully it won't cost too much.
I wonder if the different weight distribution with saddles will improve the handling e.g. less body roll?
kaszal
same low speed damping, less pack?
Post by kaszal »
In the Procat the front currently has No.3 pistons and 37.5 Losi oil. If I wanted similar static damping and less pack i.e. less resistance at speed, could I put in No.4 pistons and 40wt oil? Those plastic plastic mounts just don't transfer the force as effectively as carbon fibre and alloy so when I try to harden up the front it feel 'grotty' :?
kaszal
UK model shop with vintage Schumacher parts!
Post by kaszal »
I just bought some vintage Schumacher parts off Alun at Tay Models.
They have a up to date list of all the old stock e.g Bosscat, Cat 2000 etc.
Their email is [email protected]
Return to “Schumacher Forum”
