m2fit4u2 wrote:I have never broken any of the wideners themselves, I have both the Thundertech black plastic ones and I have a set of aluminum as well. What happens often is that the barrel nut will come loose and then you end up stripping off the 5 plastic protrusions on the inside of the wheel that hold the widener in place. I have thought about the TTR set up but do not want locked in the rear on my race chassis do to it causes more push in turns. I do have my 4WS locked in the rear, better in the snowI am planning on going with the newer type wideners were you end up drilling 5 holes in the rim. CPE, Tweaked and RC mayhem build these. My friend that races for Tweaked says that he has never had a problem with this setup. How many Clods do you have and are there any pictures of them in this forum?
Oh yeah, the TTR wideners. I meant the TTR CVDs, they widen your truck too. You can get those for front and back and they are extended at the end by 1/4" on each side. No adapters or other parts needed. I run the CVDs up front on my other Clod, and straight axles in the back, they have the same spacing, of course you could put the CVDs in back too for 4ws. These here:
http://www.thundertechracing.com/cvd1.htm
The 5 hole wideners were actually the first style I ever saw. I can't remember who originally came up with that design.
Right now I'm down to 2 Clods. My other Clod is in this thread:
http://www.rc10talk.com/viewtopic.php?f=32&t=3227&hilit=Boyer+clodbuster
And it looks like this:
