Worlds Chassis with an RPM Transmission case.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Does the RPM transmission case need to be modified when using a worlds chassis and world rear arm kit? Can I use a stealth transmission case without modification?
- Has thanked: 183 times
- Been thanked: 157 times
stock stealth case fits fine with the narrow rpm rear end.
you will have to mod the rpm case for clearance when using it with the rpm narrowed rear and/or rpm rear bulkhead. its not hard at all if you are familiar with a dremel.
scr8p has a real good description and pics of the mods in his rpm-10 post:
http://www.rc10talk.com/viewtopic.php?t=584
- 770 Views
Last post by Dadio
- 2560 Views
Last post by soniccj5
- 1669 Views
Last post by Synergy
- 26 Replies
- 4045 Views
Last post by MarkyDents
- 963 Views
Last post by Dr. Robotnik
- 1155 Views
Last post by lowrydesign
- 1686 Views
Last post by cybercrxt
- 606 Views
Last post by reign79
