Liquid mask Which one?
- Been thanked: 16 times
I have just used Parma faskmask so I can`t compare. I have seen other brands but I don`t know how they are..Which one would you recomend?
Re: Liquid mask Which one?
I use Hobbico Master Mask. It's a little cheaper then fastmask in the 3oz. size. I usally thin it with water and spray it on. I find that the larger bottles go to wast or start to clump up as the dry out over time.
- Eau Rouge
- Been thanked: 5 times
Bob Dively's LM is the only one I use. Apply unthinned with a 1" foam paint brush. Wait for each coat to dry completely before applying the next one, and apply 4-6 coats for best results.
I think I`m gonna try that one, the Bob Dively...
QBall: yeah,agree with you ,small bottles is better..Fasmask also get dry very fast even in the bottle (not so fast when you apply it though)
Take the 4-6 coat advice as the best you could get. You will say the most amt of bad words if you put it on too thin..Even a simple scheme will be a nightmare..not thatii-- well ok i have done it....
- Regular Member
- 26 Replies
- 4896 Views
Last post by szac
- 1129 Views
Last post by markt311
- 2517 Views
Last post by clm
- 37 Replies
- 5873 Views
Last post by Brendan2904
- 1809 Views
Last post by tamiyadan
- 4098 Views
Last post by josh
- 1573 Views
Last post by rctenracer
- 2928 Views
Google Feedfetcher and 2 guests
