Painted bodies but uncut
- Been thanked: 81 times
I see alot of painted bodies uncut that go for high bucks .You only get one try cut them out. How do you guys do it ?
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
Re: Painted bodies but uncut
A pair of sharp scissors around the bottom. A pair of curved scissors for the front and rear and a Dremel with a sanding drum for the tight spots. If the cut out lines are hard to see I usually test fit the body 5-10 times during the process to make sure I am only removing the material that absolutely needs to be removed for proper fit.
That's how I've been doing it for years now (eesh, probably 20+).8rad wrote:A pair of sharp scissors around the bottom. A pair of curved scissors for the front and rear and a Dremel with a sanding drum for the tight spots. If the cut out lines are hard to see I usually test fit the body 5-10 times during the process to make sure I am only removing the material that absolutely needs to be removed for proper fit.
- soniccj5
Xacto knife with a fresh blade. Score along the line, then snap it off.
Where the knife does not work, I use lexan scissors.
- RedScampi It’s my birthday!
Yep...all of the above. Just go slowly. You can always remove more material but it's difficult to put it back!
Gary
- soniccj5
RedScampi wrote:Yep...all of the above. Just go slowly. You can always remove more material but it's difficult to put it back!
Very good point. I was trimming a Sand Scorcher body and removed too much from the front nose cone
As mentioned before just keep mounting it and taking small amounts off.
- Halgar
- Has thanked: 146 times
- Been thanked: 196 times
Another option would be to purchase the same body unpainted. Cut out the unpainted version and fit it/mount it and get it just the way you like it, then slide it over the painted body and use it as a template for trimming and mounting hole placement. You'll still use all the techniques described above, but you'll be less likely to fubar an expensive body/paint job.rctenracer wrote:I see alot of painted bodies uncut that go for high bucks .You only get one try cut them out. How do you guys do it ?
- GodSpeed
I did a search and that's how I ended up in this old thread, but I couldn't find exactly what I was looking for.
Is there a template, instructions or detailed pictures floating around here as to where to cut an RC10 Classic body?
- 762 Views
Last post by Brandon G
- 2049 Views
Last post by MarkyDents
- 2077 Views
Last post by RCveteran
- 1061 Views
Last post by bearrickster
- 818 Views
Last post by SRTracer121
- 79 Replies
- 7380 Views
Last post by kevcrid
- 2507 Views
Last post by DerbyDan
- 2546 Views
Last post by Lavigna
Bing [Bot] and 2 guests
