Vintage Schumacher parts id can you help? (Pic heavy)
Peakey
Post by Peakey »
Anyone have any ideas on these ? I think most of it is Schumacher but you may know otherwise
I've got loads of these nip but with no part numbers or card hedders
The top wishboans on here I have a bag full
Here are some shock towers and a couple of top decks
If you can name any it would be a massive help thanks
8rad
Has thanked: 9 times
Been thanked: 38 times
Re: Vintage Schumacher parts id can you help? (Pic heavy)
Post by 8rad »
Top ones are Topcat front suspension mounts and steering bar.
Second pic top are Cougar 2000 rear wishbones.
Fourth pic are Cougar 2000 front wishbones.
Typpo
Post by Typpo »
Some of the part numbers with descriptions and corresponding links are as follows:
http://s1345.photobucket.com/user/peakey29/media/Mobile%20Uploads/E0D4DBC6-00CB-4840-BD6C-00E782780389_zpsvybpib31.jpg.html
Second row:
Front wishbones appear to be U1477 (CAT 2000)
http://s1345.photobucket.com/user/peakey29/media/Mobile%20Uploads/912A01F8-456D-4AFA-B2D7-A5819DCAFFD5_zps3gqxxobj.jpg.html
Bottom row: Rear Wishbones
Difficult to tell without seeing the ends of the rear wishbones. Probably either U1800 (CAT 2000 EC SE 98) or U1487 (CAT 2000)
http://s1345.photobucket.com/user/peakey29/media/Mobile%20Uploads/F4250C13-A092-4447-91FA-DAD48F79CCF2_zpsqlfixg19.jpg.html
Bottom row left corner
This part looks like part of U1804 Rear Shock and Wing Mount (CAT 2000 EC)
Bottom row center
U2009 WFE Fr. Mount CAT SE
http://s1345.photobucket.com/user/peakey29/media/Mobile%20Uploads/64C8350F-1DE1-4190-BE8B-2AD07255D8F3_zpseuqw8lan.jpg.html
Looks like U1518 CAT 2000 top deck (Note: the front looks like it has been chopped off)
Also, U1512 Idler Set, Front Belt CAT 2000 (also CAT 2000 EC and SE) is attached.
http://s1345.photobucket.com/user/peakey29/media/Mobile%20Uploads/60089DFD-4900-498D-8C7C-036159912C2A_zpsnf5bdxmn.jpg.html
Probably SST'98 top deck (part number unknown). Not likely U2067 (CAT'98) top deck or U2046.
http://s1345.photobucket.com/user/peakey29/media/Mobile%20Uploads/A825B846-F91C-421B-8214-B49FA74091A8_zpsowb59dxi.jpg.html
Left side second row
CAT 2000 Touring car conversion rear mount (part number unknown)
Left side second from bottom
This white one looks like part of U2069 Rear Shock and Wing Mount (CAT '98) but is not WFE or S1 material
Left side bottom corner
This part looks like the other part of U1804 Rear Shock and Wing Mount (CAT 2000 EC)
Right side second from top
U1483 Front Shock Brace (CAT 2000). Could be 10, 15, or 20 degree version.
Peakey
Post by Peakey »
Thanks for those guys anyone know what these are off I know I've seen them somewhere but can't find them
8rad
Post by 8rad »
Peakey
Post by Peakey »
Thanks pal I thought they were but wasn't 100%. Let me know when your stuff arrives :wink:
8rad
Post by 8rad »
I will.
The shock mount in the bottom pic with 2206 written on it has a very "prototype" look to it.
The blue parts are interesting too.
It would be great if someone has more info on these parts.
CAT3K
Post by CAT3K »
The blue parts are for the Fireblade 2000. Not sure why they are blue, but the FRP is easy enough to strip and re-colour.
Paul.
Peakey
Post by Peakey »
It's hard to find a exploded view of the fireblade 2000 but here's a better pic of the blue bits
Return to “Schumacher Forum”
