Big noob from Norcal!
- Regular Member
Hi, I recently got an old Rc10 from my uncle. I know literally nothing about its history except that it has an A stamp on the chassis. I am trying to get it running again(I know a lot of people will say to put it on a shelf). as of this writing, it does work, however not well, and one of the front arms is snapped. By not well I mean that the car drives even when I'm not touching the throttle and only when I jam the throttle trigger into full reverse does the car stop.(maybe faulty esc). but hey I'm just here to learn and have fun!
- Has thanked: 1153 times
- Been thanked: 624 times
Re: Big noob from Norcal!
Welcome! This is the place for RC10 knowledge. Be sure to vote for the Build Of The Month and we like pictures! Sounds like that esc might need to be adjusted..
-Brad
- Has thanked: 14 times
- Been thanked: 14 times
Your uncle had good taste. Get some pictures of that esc and your radio up here and maybe we can help. I'm in Fresno, depending on where you are we can plan a meet up sometime and I can have closer look at the problem. I'd also explain what does what and why. No I not going to charge you for it.
You may know me as Jessica. Or, that girl that raced a Stampede at SoCal Raceway. Maybe, that girl with the big big block El Camino.
IG and YT @ Jessica's 2 Car Garage https://www.youtube.com/channel/UCMP9VnJ76BZv6EZJSRke_pw/
- Regular Member
I am in san metao areaSoCalSnakeEyes wrote: ↑Sun May 02, 2021 10:41 pm Your uncle had good taste. Get some pictures of that esc and your radio up here and maybe we can help. I'm in Fresno, depending on where you are we can plan a meet up sometime and I can have closer look at the problem. I'd also explain what does what and why. No I not going to charge you for it.
Upon further analysis there was a screw on the esc that was labeled "neutral" I turned that and now everything works! now I need new front amrs so: https://www.ebay.com/itm/201671455244?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Dcc4aea353ecb44c7b3db123db9c06a18%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D133691781169%26itm%3D201671455244%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A20f18511-b340-11eb-bf33-2a3c66e72bcf%7Cparentrq%3A616f58481790ab8cd7e39e9effe8c353%7Ciid%3A1
- 1608 Views
Last post by shaveradam
- 604 Views
Last post by R Cane
- 498 Views
Last post by RC10th
- 1841 Views
Last post by Lavigna
- 1317 Views
Last post by CrazyRC
- 602 Views
Last post by RC10th
- 1690 Views
Last post by MrBig
- 711 Views
Last post by Jimbo302
