After putting it together, I found that the quality of the ST15 parts are not nearly as quality as the kyosho parts. The rear arms and bearing carriers are just fine, but the front bulk head is horrible, I will take you guys up on getting the stock one, the hinge pins didn't really fit because the parts were warped and I don't have a hinge pin reamer, so I put the hinge pin in a dremel and spun it in there to free it up and it worked ok, but I am not satisfied, and I had to drill out the top deck holes on the bulkhead because they were too small, but the 2 peice design sort of looks cool on there. I may have just got a bad casting.
Of course I need to get adjustible turnbuckles.
I'm not sure what the parts that came with the servo mounts are for.
The rhino steering looks like it will work great! I need to put a washer on top of the posts because there is a gap between them and the top deck, and I need to get a draglink.
The rear cvds look like they will work awesome!!!
The only thing I don't like about the JG deck is that they didn't drill holes for a front sway bar and for a body mount.
I need to find a new chassis, because I cut into it as a kid, but I just shined it and the shock towers up for now.
I really like how it is turning out, I just need a few more parts and it will be mostly complete. Does anyone know where I can find a body cage and the part that mounts to the rear shock tower and the motor mount that the body hinges on? I may be able to salvage the body cage.
Sorry if I seem to be typing in random bursts, I am tired its midnight here.
Here are some pics:
