Vintage rc10 Bearings
- Regular Member
I'm restoring an original graphite chassis RC10. I would like to know what size bearings does this car take, and how many.
i used this duratrax set
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD034&P=0
for the front and rears originaly youd need 8 flanged 1/4 x 3/8 for the wheels.BUT unless you want to scout ebay and risk paying a handful i just went with this set and used the 3/16 bearings with b2 rims for the front.i went though with rpm rear carriers and thier bearings made special for them for the rears.http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000179280&I=LXEU81&P=K
http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000179280&I=LXEU82&P=K
the duratrax set is the closes i could find but you will get all the bearings you need for the tranny and the 2 for the outdrive and diff gear.you will have an extra 6 3/16 ones though.
- Has thanked: 36 times
- Been thanked: 1318 times
if you scroll down to the post "parts required", on may 15, i made a list of bearing sizes for different applications. take a look at that. the trans bearings in that post are for the 6 gear trans. if you have the stealth, here are the sizes.
(2)- 5/32 x 5/16 unflanged
(4)- 3/16 x 3/8 unflanged
(2)- 3/8 x 5/8 unflanged
- Sharkman
You could try http://www.Bocabearing.com they carry complete bearing kits for just about anything out there.From standard cheapos to High buck ceramics,pick your poison!!
Dan
- 428 Views
Last post by carloco8
- 20 Replies
- 1801 Views
Last post by nvxwax
- 2420 Views
Last post by RC104ever
- 1995 Views
Last post by shodog
- 1987 Views
Last post by Winger
- 637 Views
Last post by cherokee
- 726 Views
Last post by sneako43
- 543 Views
Last post by FordPSD
