Katana restoration
shodog
Been thanked: 91 times
Katana restoration
Post by shodog »
I have wanted to restore my Katana for a while now. It was my brother in laws bike before he gave it to me and he had low sided on it and scraped the body work. I looked at repairing and replacing some of the broken panels. I found it was just easier to order the pre-painted body kit from eBay sellers out of china. So today I embarked on the task of tearing down the bike.
I need to paint the tank a contrasting color but before I can do that I need to prep it and fill a couple of dents. I used a weld rivet gun to get the dents out and then used aluminized body filler.
m2fit4u2
Re: Katana restoration
Post by m2fit4u2 »
I have replaced many cosmetic panals and fairings on bikes, they are so much easier to work on than cars. I like the copper looking color you went with; is that copper by the way :?: I first liked copper on bikes when Suzuki came out with it on their 99 Busa, gorgeous bike I must say.
vwjuice
Post by vwjuice »
What model Katana is that. I used to have a 2007 katana 750. I loved that bike. I want to get nother one soon.
shodog
Post by shodog »
My Katana is a 2000. The new body work has the updated 2006+ tail so I have to figure the new tail light wiring
I really like the copper/orange color also. It's not a very common color you see on bikes
Has thanked: 306 times
Been thanked: 415 times
It was on 2004-2006 Suzuki Sv650's :twisted:
justinspeed79
Post by justinspeed79 »
Cool project, cool bike, Showdog. 8) It looks pretty clean too, other than the obvious. I am currently working on restoring my 2000 Suzuki Bandit 1200s. Unfortunately mine was a little worse off than yours, but I got lucky and found a good parts bike for $400. I have had a lot of fun with it, and plan on having a lot more too. :mrgreen:
justinspeed79
I like the pink scissors too. :P
skunk.werkz
Post by skunk.werkz »
Life is always better on two wheels :wink: 8)
shodog
Post by shodog »
This project has taken a bit longer than expected but I have lots of progress to report. I cut the rear shovel looking fender off.
Then after mounting the tail found I need to cut way more off.
Here is the completed the rear tail section. I have found there are a allot of differences between this 06+ replica and my '00 tail and this project has been more work than I expected. I was going to use a blinking LED tail light and skip the turn signals but I didn't like the way it operated. So in the end I used a stock tail light and aftermarket slimline blinkers. I had to fab up a new longer cable from the lock to the seat unlatching mechanism.
Then I used a fender eliminator to give the underside a clean look.
The forks had some corrosion on them I wanted to remove.
I removed the clear coat from the forks with Jasco paint stripper.
I tried giving them a nice buff 400 grit finish but I wanted more bling. So I sanded them with varying grits to get it smooth enough to polish. I used Mothers with a buffer ball to get them pretty shiny. Then I sprayed Tamiya clear orange paint over them and finished with a clear coat. I like the results.
markt311
Post by markt311 »
Wow, that is turning out nice. Very good work I'm hoping to get a 1:1 project going soon as soon as the wife and I get into the new house.
Mark
justinspeed79
Looking very good. The forks look amazing! 8)
pituk
Post by pituk »
Looks good , maybe you can fit a Gsxr fender on there. Its a bit larger for the upside forks so it may help protect your forks against rock chips. I still have my Yamaha Fzr400 that I bought in 89 (sheesh has it been 20 years already) hopefully someday I will get it going again.
shodog
Post by shodog »
Thanks for the compliments. Today i sprayed the front fender and rear grab bar with Metallic black paint. It looks pretty nice and even better after a few clear coats.
shodog
Post by shodog »
I have been busy working on my bike. I am missing some really killer ride weather. I should have saved the project for winter. The fender that came with the plastics kit isn’t for my bike. It’s a completely different shape and hole drilling. So I sanded and painted my original fender. I went with a color called Metallic Black. It looks like a dark metal flake grey. It really compliments the other parts and makes the fork color pop. It has a taken some time to do these as wet sanded between coats to keep the paint job butter smooth.
In addition to the fender, I did the rear grab bar the same color.
Next up is the Tank. I have the color coat and 3 shots of clear done in this pic.
I wet sanded the clear coat with 1500 to get a nice flat surface to shoot another clear coat.
This is with 30 minutes of drying time.
shodog
Post by shodog »
I got it all back together and have been riding it the last few days. I really like how it turned out. Now I can focus on other projects I have been putting off.
Users browsing this forum: No User AvatarMojeek [Bot] and 11 guests
