Anybody ever try this???
So as I'm sitting here rebuilding my old Stealth tranny I see my tranny from my B4 is sitting off to the side......hmmmm.......anybody try to run the top shaft off a B4 in the old Stealth, so you can use the B4 slipper and spurs????
I just finished it and it seems to be a great fit (I just mocked it up quickly), if using the stock gear cover the shaft sticks out a hair further than the stock top shaft. The spur seems sit almost in the same position if not a hair closer inward. All in all I think this is a great swap, no more old thrust washers of slipper rings etc... Plus just like Superfly said B4 parts are alot easier to find.
All you need is a B4 top shaft, slipper hubs, slipper pads, spur, and slipper spring and nut. And I'm sure it probably works a whole lot nice than the old one.
-Josh
-Josh
