Monster Beetle rebuild...slow
sneako43
Post by sneako43 »
I just put my old MB back together (using a Frog chassis). I rebuilt the Thorpe ball diff (using new balls) and it felt smooth when I turned it by hand after assembly. When I apply the throttle, the wheels turn fine if the truck is not on the ground. As soon as it is placed on the ground, it just creeps. I have tried different motors, pinions, and batteries all with the same result. Any thoughts?
SC10 -- FT B4.1
aconsola
Re: Monster Beetle rebuild...slow
Post by aconsola »
is it creeping slowly even though the motor sounds like it is spinning fast, or is the motor bogging down?
sneako43
Post by sneako43 »
aconsola wrote:is it creeping slowly even though the motor sounds like it is spinning fast, or is the motor bogging down?
The motor is definitely still spinning fast (normal speed). It just creeps. I'm going to dismantle the ball diff and replace all the balls. I think that maybe I didn't use enough of the 1/16 balls. Do you think that may be the cause?
Thanks for the response.
SC10 -- FT B4.1
aconsola
Post by aconsola »
if the motor is going fast but the truck is not moving much, the diff is likely loose. I would take it apart, clean and inspect the whole diff. re-assemble carefully and make sure that if you hold both of the outdrives you cannot spin the iff gear by hand.
sneako43
Post by sneako43 »
aconsola wrote:if the motor is going fast but the truck is not moving much, the diff is likely loose. I would take it apart, clean and inspect the whole diff. re-assemble carefully and make sure that if you hold both of the outdrives you cannot spin the iff gear by hand.
Cool. I will see if that works and I will let you know. Thanks!
SC10 -- FT B4.1
sneako43
Post by sneako43 »
It worked! Thanks for the advice. All I need now is a body. Any recomendations on a motor? I'm keeping it simple...no LiPos or Brushless power needed. A 27T?
SC10 -- FT B4.1
sneako43
Post by sneako43 »
Anyone know if the King Blackfoot wheels will work on the Beetle?
(http://myatomic.com/catalog/viewsku?sku=TAM9335253&itemname=wheel_bag_58192)
SC10 -- FT B4.1
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
Check with mr .Lexan see if he still has the reproduction scorcher monster beetle bodies.I bought 2 from him their sweet.Their Lexan bodies not original hard bodies.Don
sneako43
Post by sneako43 »
THUNDERSTRIKE1 wrote:Check with mr .Lexan see if he still has the reproduction scorcher monster beetle bodies.I bought 2 from him their sweet.Their Lexan bodies not original hard bodies.Don
Thanks, I'll hit him up. I've heard he is a popular guy on this site!
SC10 -- FT B4.1
cyclepsych0
Post by cyclepsych0 »
sneako43 wrote:Anyone know if the King Blackfoot wheels will work on the Beetle?
Fronts will bolt right on. Rears will need the 5-pin adaptor on this HPI tree....
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000471732&I=LXN057&P=K
sneako43
Post by sneako43 »
Thanks, man. I saw those included with an HPI wheel set. The King Blackfoot wheels would look cool since they are red and match a lot of the plastic on the chassis.
SC10 -- FT B4.1
shodog
Been thanked: 91 times
Post by shodog »
I like the look of the chrome KBF wheels on the Monster Beetle. Everytime I open this post I hoping to see pics.
sneako43
Post by sneako43 »
shodog wrote:I like the look of the chrome KBF wheels on the Monster Beetle. Everytime I open this post I hoping to see pics.
I can do that, Shodog.
SC10 -- FT B4.1
Return to “Tamiya Forum”
